A6 C6 ECU swap
Results 1 to 15 of 18
Thread: A6 C6 ECU swap
    Dec 2019
    Downloads
    Uploads
    Default A6 C6 ECU swap
    Hello.
    I have an Audi A6 4F 3.0TDI 2006 and i want to do a ECU swap with a used ECU i bought from eBay.
    I read on rosstech that i need old and new PIN.
    What tools do i need to find out the PIN ? VagTacho is ok for this model of ECU (EDC16) ?
    Thanks in advance.
    kumistheru's Avatar
    Aug 2013
    165
    Downloads
    74
    Uploads
    Read your original ecu using ecu programmers like KTAG, FGTECH etc and transfer it to second hand ecu.
    Dec 2019
    Downloads
    Uploads
    No can’t do that.
    My original ECU is with stock map.
    The used ECU has ABT tunning map.
    Long story short, both ECU’s have the same P/N.
    Mine is stock, the other one (used) is from a car with modifyed software by ABT Tunning.
    Nov 2018
    Poland PL
    10
    Downloads
    Uploads
    you can add the used ECU to the car, but the procedure from Ross-Tech using the PIN code on the A6 C6 does not work. you need dedicated diagnostic equipment for Immo.
    you can still try to rewrite only eeprom
    Mar 2019
    Germany
    Downloads
    Uploads
    Yes, the easiest way should be reading and writing eeprom data from original ECU to new ECU or reading flash from new ECU and write to original ECU. Everything via BDM port. ECU is secured with breakaway bolts.
    Nov 2014
    35
    Downloads
    4
    Uploads
    If you post Ori and New ecu EEPROM dump I can make a one for you
    Enviado desde mi Aquaris_A4.5 mediante Tapatalk
    Dec 2019
    Downloads
    Uploads
    I do not want to read and write eeprom.
    I just want to know what tool do i need to find out the old and new pin.
    Wondering if VagTacho works with this model of ECU (P/N 4F0 907 401 B).
    Nov 2018
    Poland PL
    10
    Downloads
    Uploads
    I don't know what you expect ?
    I wrote to you that in the C6 model you need the PIN for nothing and you won't do anything with it
    To adopt this ECU, you need to sell. to Immo. PIN, CS, MAC, PC needed for adaptation. the ability to do ImmoOff too
    Dec 2019
    Downloads
    Uploads
    You don’t know what you are talking about.
    There is no need to do IMMO Off on A6 C6 because it has another module (under the steering wheel, on the steering column) where the IMMO info is.
    The car starts just fine without the Instrument Cluster or with another ECU.
    The problem is that the VIN number must be adapted on the NEW/USED ECU.
    To adapt the VIN you must have the PIN for the old/original ECU and the new/used ECU.
    P.S I expect what i asked earlyer, to find out what tool i need to find the PINs.
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    219
    Downloads
    4
    Uploads
    Quote Originally Posted by MichaelKors View Post
    The car starts just fine without the Instrument Cluster or with another ECU..
    when someone before successfully has done immo off in donor ecu, then yes...
    in other the car will not start...
    and I think that you don´t know what are you talking and writing about...
    I thouht you are asking questions and need help...?
    or you want teach them how to solve your problem...?
    Nov 2018
    Poland PL
    10
    Downloads
    Uploads
    I will not write anything else, because it is a waste of my time to explain.
    Good luck...
    Dec 2019
    Downloads
    Uploads
    From the begining, i wanted to find out with what tool i can find the PIN.
    Then you deviated the disscution to IMMO , etc. Irrelevant, i just want to know the PIN.
    Or did you saw me asking about IMMO, EEPROM, CS, etc ? When did i did that ? Because the is all you are talking about.
    If you know the answer to my question “VagTacho works with this ECU?”, please respond, if not, please keep calm and don’t reply.
  13. #13
    figani's Avatar
    Feb 2018
    219
    Downloads
    4
    Uploads
    first, stop spaming...
    second, if you don´t like answer use logout button..
    and third if you write also accept the reactions from other...
  14. #14
    Dec 2019
    Downloads
    Uploads
    Spam?
    From the begining i asked a question.
    You all deviated the disscution.
    Firstly, the procedure from rosstech works just fine.
    I replaced The ECU on another A6 with that procedure. But then i had the PIN’s from both ECU, now i don’t.
    You don’t even know where the immobilizer is on a A6 C6 but you still continue to talk crap.
  15. #15
    figani's Avatar
    Feb 2018
    219
    Downloads
    4
    Uploads
    Spam?
    thanks for explaining where the immo is located...
    in post 9 you had demonstrated a big part of your knowledge...
    and again, stop spaming...
