Results 1 to 7 of 7
Thread: ex700 hd+
    Top Poster funkyuk's Avatar
    Default ex700 hd+
    hello can any 1 help i have a ex700hd and a starview box super may b the snow not sure but lots of channels are pixelated bad on both boxs some are fine some so bad cant watch can any 1 help plz ???
    V.I.P. Member chic.'s Avatar
    Feb 2009
    glasgow
    Hi m8 remove any splitters and make sure all the connections are nice and tight if you need a splitter get a good one from maplin's
    Quote Originally Posted by chic. View Post
    HELLO AND THANKS i removed all splitters done reset the lot and still the same can this b the n3 thing ??
    Feb 2009
    glasgow
    no if it was n3 you wouldnt see the channel , your signel is breaking up check the cable right back to the small white box , if that is ok go to user installation and check the signel strenth on all the freq's if 1 is to low( ie 80 ) then press add and change up by 200 (ie 236,000 to 236,200) then scan that freq this could take a while but it should work BUT CHECK THE CABLE FIRST
    in the midlands
    Default rontwo
    hi to all. great forum.
    Feb 2009
    glasgow
    Quote Originally Posted by rontwo View Post
    Hi welcome to the forum m8 there are alot of good people on here
    thanks for the help m8 i took the splitter out for modem rescan all fine now cheers pal
