Results 1 to 9 of 9
    baltazar3's Avatar
    Andromeda
    Default Jaguar GX73-14D374-AJ 0285013333 Crash
    Hello to all !
    Need to clear crash on Jaguar XE
    Here is readout od EEPROM 95640
    Need tested clear if possible ..car is far away.
    Thanks in advance !
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
    Dec 2017
    Post TRY IT
    try it bro
    Jan 2014
    Default airbag
    TRY AND REPORT,
    PASS IN PM.
  4. The Following User Says Thank You to chafik4051 For This Useful Post:
    baltazar3 (5th December, 2019)
    slick_dick's Avatar
    Essex
    i have tested solution but you will need to clear dtc's on bench prior to fitting in car!
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
    slick_dick's Avatar
    Essex
    Quote Originally Posted by baltazar3 View Post
    Hello to all !
    Thanks in advance !
    your file cleared
    pass in pm
    br
    slick
  7. The Following User Says Thank You to slick_dick For This Useful Post:
    baltazar3 (6th December, 2019)
  8. #6
    baltazar3's Avatar
    Andromeda
    Quote Originally Posted by slick_dick View Post
    your file cleared
    pass in pm
    br
    slick
    Need pinout to clear DTC on bench
  9. #7
    slick_dick's Avatar
    Essex
    pm sent
  10. #8
    Apr 2020
    Hello friends!Here's a problem from inspector warnicke. Jaguar XF 2016 year. GX73-14D374-AJ 0285013333
    EEPROM 95640. On the table reads all errors. Including the B1193 crash. Already tried seven times , and the sample on the table does not read. Errors don't open. If I upload the crash back, it reads errors again. Please help us solve this problem!
    [ATTACH]708977[
  11. #9
    norfolk uk
    can someone help with crashdata on 2016 jaguar f pace. gx73-14d374-aj 0285013333
