    yarokas's Avatar
    May 2019
    Portugal
    Default Renault Dacia 985106332R r7f701013 crash clear
    Does some one have solution for this ecu?
    Renault 98510633R
    Continental A2C17351701
    MCU Renesas RH850 r7f701013
    Attached Dflash and Cflash.
  2. The Following User Says Thank You to yarokas For This Useful Post:
    datapage (6th September, 2021)
  3. #2
    yarokas's Avatar
    May 2019
    Portugal
    Maybe some one can check if this is the solution?
  4. The Following User Says Thank You to yarokas For This Useful Post:
  5. #3
    Feb 2020
    Hi , did you found a solution for this ecu?
  6. #4
    EARTH
    [QUOTE = yarokas; 3738744] Talvez alguém possa verificar se esta é a solução? [/ QUOTE]
    ECU ERROR
    Dec 2010
    is possible clear crash ?
    thanx for help
    edit:
    just solved.....
    no need now
    thx
  8. #6
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    Tell us how you solved it
