Results 1 to 3 of 3
    g5n14's Avatar
    Aug 2018
    Default Skoda 1.2TSI 2017 PIN
    Hello guys!
    I have Skoda 1.2TSI 2017, all keys lost.
    Owner bought a precoded key from VW. Now I need to code it.
    Is is as simple as get the pin out of ECU and then code it with VCDS? Never worked on VAG later than 2010 before.
    Thanks for answers in advance!
    Garage
    Yes you can get code from ecu and also from dashboard.
    Read eprom from ecu or read dash and some one will give you pin code.
    Then with vcds learn key.
    g5n14's Avatar
    Aug 2018
    Thank you for your reply!
    I will read the ecu eeprom and post here if my EFfi software cant handle it.
