Results 1 to 7 of 7
    Aug 2009
    Default Mercedes w203 EZS Activation + Key Activation 1J35D
    Hello,
    I have Mercedes w203 EZS partnumber 2035450508
    Car has 2 keys, someone mess with EZS and made problems...
    Now remote control donīt work, key rotates in EZS but donīt start engine.
    I check values with diagnostic tool and see that EZS is de-activated.
    And all key tracks are de-activated. So, it seems someone de-activated everything.
    I removed processor 1J35D to read with ETL.
    File is attached.
    Can someone help me activating EZS and key tracks ?
    Many thanks for your help
    Dec 2009
    Garage
    Do you need key calculation also?
    Aug 2009
    No, I donīt need key calculation.
    Only need EZS activation and key tracks activation.
    Thanks !!
    Dec 2009
    Garage
    I am sorry I cannnot activate this eis.
    Maybe some one write wrong dump inside eis .
    Try to find on forum dump eprom from same eis no and write this dump this must work but you must make new keys.
    Do you have mb star diagnostic?
    Did you try to activate with star?
    Here is in info some passwords if you need.
    Aug 2009
    Sorry, I donīt have MB STAR to try to activate EZS.
    Is someone able to edit my dump to activate it ?
    Thank you
    Feb 2010
    Germany
    Feel free to try this dump. I have reactivated all keys and set the first 3 keys as used. The second dump is only reactivated all keys to unused. I think you should try this dump at first.
    Good luck.
    Greets MR...
  7. The Following User Says Thank You to brobble For This Useful Post:
    aqua_life (6th December, 2019)
  8. #7
    Aug 2009
    Thank you.
    Your file worked fine.
    With your file I was able to activate key and start the car.
