Hy..what error you have pls ? ..if it's the pretensioner resistor error it will come back every time ..it's not an airbag unit error !!!
Hello friends.
Please, I need to clean a Citroen C3 8200419152 55056900 Eprom 93c66 file. I made a few attempts, but it didn't work out. The light goes out and a few seconds later comes back on.
The car is far away, would anyone have a 100% tested solution?
Thanks in advance and I will not forget the magic buttons ...
In case my help has been useful do not forget the magic buttons. ( Thanks and * Reputation ) !!!.
ATTENTION!!!
Attempting to clean files is only to help members. By using these files, you agree to assume the consequences and are aware that all liability for any damages is entirely yours.
Thank you!
megabits.
ATTENTION!!!
Thank you!
megabits.
I think you was erase the crash error(i was in same problem)..now you left with resistor problem...i think...but you can try with another solution's too ..i think without succes ...
Maybe you can ask someone to make a test and give you the error code's...
megabits (6th December, 2019)
ATTENTION!!!
Thank you!
megabits.
if no dtc's why not unlock or lock unit down via special functions?!
“There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
..i found only one solution..try it if you want and report back..br
ATTENTION!!!
Thank you!
megabits.
ATTENTION!!!
Thank you!
megabits.
slick_dick (6th December, 2019)
Does anyone have a clear file tested for this car?
ATTENTION!!!
Thank you!
megabits.
