Results 1 to 15 of 24
    May 2019
    Question CAS4+ AKL cranks but will not start
    Hello, I did a 2014 650i CAS4+ on Bench by VVDI2. Wrote the key by file, it will crank but will not start. The remote doesn’t work too. I’ve got the right frequency 315 fob. Did diag shows wrong key security code, doesn’t match CAS. any help please!? Thanks
    i did search the forum for previous posts but couldn’t find anyone else with same situation.
    Oct 2018
    hi upload all file
    Sep 2016
    Cas4+ as far i understand need isn from ecu. Did you read it too?
    Dec 2016
    If you had save original file , upload it in CAS 4 , and bought a key to local BMW dealer !
    Too complicated job for money ...
    Dec 2016
    Quote Originally Posted by qeso705 View Post
    Cas4+ as far i understand need ISN from ecu. Did you read it too?
    Yes he can !
    May 2019
    Default D-Flash, P-Flash (just in case), ECU ISN and Codings
    Here you go mate. I have uploaded whatever I had retrieved. Thanks
    May 2019
    Yes, indeed. I read ECU ISN
    May 2019
    Quote Originally Posted by TERMINATOR1000 View Post
    Yes he can !
    You mean I can make CAS4+ all keys lost without ECU ISN? Thanks
    May 2019
    Quote Originally Posted by tothzsolt View Post
    hi upload all file
    Sorry my first post. How do I upload files. I selected video, image and advanced but I see nothing is uploaded. Thanks
    Dec 2016
    Quote Originally Posted by ashakoors View Post
    no , you need it
    Dec 2016
    use "mega" , if you can't use forum advanced function
  12. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
    cristyand (25th May, 2020)
  13. #12
    May 2019
    It is easy bro but never run to that situation before
  14. #13
    May 2019
    no , you need it
    I know bro but thought you can do it without ECU ISN
  15. #14
    May 2019
    I’ll do that. Thanks
  16. #15
    May 2019
    OKay, Finally, I got to upload the file. Thanks
