No immo off for such ecu
Read tms ic in immo around ignition key
Extract pin code and code new transponder id 40 via obd
Or from dump via tango or tm100
Hello there,
I got an Opel Vectra B witch is not starting.
As i check i observed that the owner does not have the Transponder into the key.
Is there any way to make immo off since the owner does not have the transponder anymore?
Part Number: 16202319
Aplha COde : NL
Ecu TYpe: X16XEL
Thanks!
BadeaCristian (8th December, 2019)
you can do immo off in this ECU. You have the pattern in the attachment. You must disconnect immobox. Dont forget click thanks and reputations.
alexeybulatow (4th January, 2024), BadeaCristian (8th December, 2019), beepprog (2nd November, 2020), kork12345 (7th October, 2022), misho2318 (21st May, 2021), zaycew (8th March, 2021)
you need a new id40 transponder or precode one pcf7935 to id40 with zedbull ...
Autotuner- Kess - Ktag, genuine master tools.
i have same ecu anyone to help me immo off?
Aplha COde : NL
Ecu TYpe: X16XEL
