For good job only virgin obd2 away and then programming.
Hi. I have problem with learning cluster to ECU.
I have old and actually cluster PIN.
Log actually PIN in cluster, go to adaptation 50 channel, write old PIN and VCDS schow System Not OK.
I tried different combinations, first login in ECU, then in Cluster... set 00 km in cluster, save 000 on 00 adaptation channel...
I attach files from both clusters.
Old Cluster - Mono - 8E0920900K
New - Color - 8E0920930R
To adapt these clusters, the best and fastest way is to rewrite some of the ImmoData files
Immo is on in ecu?
Yes, show VIN and Immo ID in 01-Engine menu.
Are you set cluster back from new mode after looking for pin before trying adaptation in car? Are You use correct login with 0 (0xxxx) ?
I do not have any problems with cluster change in audi cars , using ross-tech immo wiki information.
PIn's are OK. VCDS doesn't return an error after login in ECU and Cluster.
Cluster is now in New Mode - 04 status. But I tried too in Adapted Mode - 06. It's the same - System not OK.
Cluster must be in adapted mode 06.
new cluster in car, login with new pin 3516 ( enter 5 numbers , with zero first - 03516), adapt. ch 050, test, enter OLD PIN (5 numbers with zero first too)
in new value field , test, save, yes, back, close controller ignition off , wait 1 min. ign on -cluster adapted. I do it many times, do not have any problems.
In witch step you have ,,system not ok"" and in witch field it show?
Ok, back to 06 - Adapted Mode.
Immo ist ON
Go to Cluster --> Login --> 03516 --> OK (auto back to cluster menu) --> adaptation, channel 50, write 00538, at the moment show Wait, and next System Not OK.
PIN 0538 is the same in ECU and Cluster.
I tried different combinations, mileage to 0, mileage to old cluster, login first in ecu, save 000 in 000 channel adaptation, new mode, adapt mode etc etc...
I have read several topics with the same problem, nobody solved it by VCDS.
need help
now my goal is to buy xp-005
who will help?
RB4 is probably immo III generation ? ? ?
need help
who will help?
The same problem like here: https://youtu.be/_xHcTKtEzkQ
May be Your problem is using LITE version, lite do not have all functions allowed , in video also is lite version. I have ross tech official registred interface, I do not have any problems.
