Results 1 to 8 of 8
    Jan 2019
    Default Soldering Station
    What do you think about this soldering thing for carprog 8.21 and kess rework ?
    https://www.aliexpress.com/item/3295...chweb201603_53
    and this heat gun https://www.aliexpress.com/item/1000...chweb201603_53
    It will be enough for reworks ?
    Nov 2019
    Spain
    I think the welder is a bit acceptable but the heat gun won't work for you. I would look for a heat gun with adjustable temperature
    Jan 2019
    what "a bit acceptable" means ? Do not recommand?
    Nov 2019
    Spain
    Quote Originally Posted by Andr33iy98 View Post
    I think the soldering iron is not for intensive use but it is good if you used it occasionally. Sorry for my bad English
    Enviado desde mi SM-G950F mediante Tapatalk
    Aug 2018
    you have to take a 2 in 1 station
    a good brand that doesn't cost much is yihua
    Nov 2019
    Spain
    Quote Originally Posted by elmer9 View Post
    effectively, and has spare parts of everything
    Nov 2019
    Spain
    something like for example this is not excessively expensive and works well
    https://www.amazon.com/YIHUA-Solderi.../dp/B07RY5XWVG
  8. The Following User Says Thank You to zpubgz For This Useful Post:
    Andr33iy98 (8th December, 2019)
  9. #8
    Newbie Orchid70's Avatar
    Aug 2015
    SWEDEN - Sjöbo
    KSGER both soldering and heat gun stations are small and good qualitey.
    You use T12 irons - if you dont solder much you can use China ones - or you can buy Hakko irons.
    I would recomend buying from the original seller:
    https://www.aliexpress.com/item/4000...403b4c4dvqQBtM
    This is their store:
    https://www.aliexpress.com/store/1486111
