Results 1 to 3 of 3
    Nov 2008
    Default Fiat Ducato 3.0jtd EDC16C39 speed limit adjust
    Hello, please i need adjust speed limit for this file to 145kmh can you help me please? I check adjust this in address 1B5026 and 1F976E maps 2x1 and not work me. Thank you for help.
    WinOLS (Fiat Ducato (Original) - 393608).zip
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Try this one and report back.
  3. The Following User Says Thank You to Inquizit0r For This Useful Post:
    mecsoun (10th December, 2019)
    Nov 2008
    Hello, i need activate speed limiter. Car is without speed limit and we need set speed limit to 145kmh. Your solution is for speed limit disable.
    My solution works. If set value to 14500 so car go cca 155kmh in tacho. Set to 13000 car go 140kmh on tacho. I thought my solution didn't work because the car was going faster but I forgot that the speedometer was lying.
    Thank you for help
