no problem for IMMO off in EDC17C49 EDC17CP52
here tested immo off
NikoDiag (20th January, 2021), sa80libero (6th June, 2020), systemlinux (9th December, 2019)
not work solution
alclot (10th December, 2019), caliskan71 (10th December, 2019)
0281017455
hi i have the same problem, i need immo off on iveco daily edc17c49.
can you give me the password of the tested file.
Bueno, ya he podido hacer la inmovilización por mi cuenta, a través de prueba y error, he lo que he visto, todos los edc17 tienen la inmovilización en casi los mismos lugares.
por cierto este foro se está volviendo cada vez más pagado por lo que veo, se quitan las ganas de ayudar, en fin le dejo el immo a quien quiera el archivo yo estaré dispuesto a enviárselo gratis.
enviar pase pm.
pinotec (15th January, 2021)
If you want to try my file on an iveco with the same reference and you will see that it starts, if not, it is that I see ghosts or I was drunk when I delivered the car, the car from here has started starting.
by the way lines to modify
0000A9AA
000A8DDC
0013CBF8
you want more friend, before speaking you have to respect.
You haven't discovered anything new. I wrote about it in the forum.
The typical solution 8B02 2022 > 0000 8212 only works in old Iveco Daily up to 2013. (except 0281020149) Just search for the data string in hex #0FF480208B0220220090.
The data (lines) you wrote are only for SW P_842_EDC17C49_880 in edc17c49 0281017455 There are more SW versions: 771, 871 etc. Search method as I wrote above. To complete the set you still need to remove DTC errors. This method leaves immo error in BCM without original key.
Iveco only.
car_soft_gorj (30th September, 2023), esse (16th January, 2021), publiperro (18th January, 2021)
I am not saying that I have discovered it, but that without help I have had to investigate with trial and error.
As for the dtc, if there is an original key, so the bcm does not send the dtc as an unrecognized key, already explaining to me in the lines that the dtc must be found, I already know how to do the complete immo,thank you for the explanation.
What if in one way or another the car is immobilized and starting, the only difference is that not recognizing the original key will create the dtc, is what I wanted to clarify to the partner esse.
As you can see in the photos, your values are in the addresses mentioned above by me.
do you know the dtc number of the bcm to study the file with winols and remove the dtc in the next iveco?
Edc DTC: 0xC426 wrong immo code. From what I remember it also leaves an error in the BCM DTC: 0x9001.
I have not used this solution for a long time. Also the emulator is sh... The correct solution does not generate DTC errors.
Iveco only.
publiperro (19th January, 2021)
Hi, I got allready modificated ecu with no wortking immo off. Can you make me working solution. there is 8B02 2022 > 0000 8212 allready. Thank you
