Vectra C CIM replaced
Results 1 to 4 of 4
    Jan 2019
    22
    Downloads
    23
    Uploads
    Default Vectra C CIM replaced
    Hi, I've replaced my Cim with one second hand, everything is fine, car runs fine, no errors, but... remote functions are not working, I need to open/close via log/hub(u get it). Also before Cim replacement remote keys did not worked, Should I buy the same BCM from donor car and get rid of all problems ?
    BCM is well programmed, but I cannot see Remote key erase like corsa C in opcom.
    Jan 2014
    139
    Downloads
    3
    Uploads
    If I remember correctly, you must have a PIN code and delete and program existing keys with remote controls.. Also PIN is needed to SAS calibration...
    If I helped, please click button "thanks".
    It does not cost you anything.
  3. The Following User Says Thank You to jarek88 For This Useful Post:
    Andr33iy98 (9th December, 2019)
    Jan 2019
    22
    Downloads
    23
    Uploads
    Quote Originally Posted by jarek88 View Post
    calibration...
    How to erase remote keys with opcom ? I did not find this functions.
    Jun 2009
    38
    Downloads
    60
    Uploads
    You have a HITAG system and in it the transponder and remote are linked together, the same is in CORSA D! When programming keys, you immediately program remote. A description of CIM programming is in the OPCOM instruction files. CORSA C has a different system.
