    Apr 2012
    Serbia/ Hungary
    Default Toyota hilux 2.5 D4D immo off
    i want to do immo off the toyota hilux 2007 year 2.5 D4D 88kw. you need to remove the immo box or cut enough of the two cables at the ecu?
    Autotecno2006's Avatar
    What year ? What fault on immo ?
    Apr 2012
    Serbia/ Hungary
    2007 year immo not fault, ECU changed
    Aug 2015
    Simply sync ecu & immo just like the above image for 35min with ignition onindex.jpg
  5. The Following User Says Thank You to Voltish For This Useful Post:
    Gferi (10th December, 2019)
    Apr 2012
    Serbia/ Hungary
    used ECU sync?
    Apr 2012
    Serbia/ Hungary
    I don't know why, but it works. i did the immo off but didn't try to see how it works. I added the contact for 35 minutes. I connected pins 4 and 13 in the OBD connector. started. no error code
