Results 1 to 5 of 5
    Default Audi A6 airbag Crash data
    Have this A6 here with airbag fault no history guy just bought it but obviously painted.
    Module is 4H0 959 655 C with 95640 eeprom
    Has fault B1001-11 Airbag igniter stage 2 driver side short circuit to ground.
    I cant find any issue with the airbags.
    Attached is dump from airbag module 95640
    Can somebody check / clear crash data
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    Your cleared file but i think there's a problem with the connection, try putting a resister in the plug and see if the fault goes.
    Pass in PM
  3. The Following User Says Thank You to AB4S For This Useful Post:
    huwalsh (9th December, 2019)
    AB4S - please confirm pass, not accepted
    No joy got :
    B200042 module faulty
    B200094 module faulty
    B100712 belt tensioner front passanger side
    Put new module , coded and all ok
