Thread: Bmw F10
    Jul 2018
    Libya
    Default Bmw F10
    Hi mates , Im facing an issue with Bmw F10 2011
    There is no communication with VTG and I have checked the 12 V and Ground wires , i have checked the flaxray wiring plus the wakeup signal wire ,
    and I have replaced the VTG but still have the same problem .
    the fault code for VTG is
    S 0270 No communication possible with transfer box control unit
    I have another faults in the ZGW
    801C60 zgm, No flexRay intialisation
    CD0421 zgm , flexRay line fault on path 1
    CD0425 zgm , flexRay line fault on path 3
    CD0427 zgm , flexRay line fault on path 4
    CD0429 zgm , flexRay line fault on path 5
    CD042B zgm , flexRay line fault on path 6
    CD042D zgm , flexRay line fault on path 7
    thanks in advanced
    Can L and H?
    Jul 2018
    Libya
    I have checked the Can bus High and low the wires are good and i have follower the wires to the zgw
    Jul 2018
    Libya
    problem solved central gate way wasn't seeing VTG but now i have to write vo in central gateway its going to be my first time using Eyes wish me luck
    Quote Originally Posted by mzakoor1141 View Post
    Aug 2020
    How was the problem "solved"?
    Jul 2018
    Libya
    replaced vtg control and gateway
