Results 1 to 15 of 32
Threaded View
    Dec 2019
    Default CD400 Vin Change with CRC
    Could someone help, I need the VIN changing in the attached file to suite W0LPD6EC9A8043617
    Also does this eprom hold the options, I would like to enable USB and BT (this radio already has BT) I have read you need globaltis, I have access but I also read that it will not allow you to change the options as they are matched to the vin, is this correct ? or can I just select a different calibration file (I havent tried) I have how ever updated the modules
    Thank you in anticipation
    Neil
