Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Dec 2019
    Default CD400 Vin Change with CRC
    Could someone help, I need the VIN changing in the attached file to suite W0LPD6EC9A8043617
    Also does this eprom hold the options, I would like to enable USB and BT (this radio already has BT) I have read you need globaltis, I have access but I also read that it will not allow you to change the options as they are matched to the vin, is this correct ? or can I just select a different calibration file (I havent tried) I have how ever updated the modules
    Thank you in anticipation
    Neil
    Feb 2010
    WALES
    Quote Originally Posted by NeilD View Post
    Neil
    Here you go with new VIN and CRC's fixed
    wbr
    Dec 2019
    Thank you for the file, can I reprogram the eprom in situ. or do I need to remove it, also can I replace it with a DIP socket and normal eprom as opposed to a surface mount one ? Thnx
    Feb 2010
    WALES
    Not enough room for a non-smd device, also why would you???
    Can use a Chip-Clip but not recommended
    wbr
  5. The Following 2 Users Say Thank You to shooting For This Useful Post:
    miroopel (19th April, 2020), NeilD (31st December, 2019)
  6. #5
    Dec 2019
    Default Test and new install plus other
    Quote Originally Posted by shooting View Post
    wbr
    I think becuase of the signal type I might be able to run the socket wired, I'm sure you are familiar with the cruze forums in the USA, On there one of there more learned users is saying he has (20') out the whole VIN and then the radio acts as though its a first install, I have a spare cd400 I'm going to try this out on, and he doesnt mention the 2 hex bits that you change (checksum) and it seems many have tried it, you mention a test mode ?? if the bytes are not set
    Also can you comment on the calibration files I questioned above please
    Regards
  7. #6
    Dec 2019
    Default Quote from Cruze Forums
    wbr
    dhpnet said:
    On the right side, look for a string of numbers that look like a VIN. It is usually only a few lines down from the top. It is always missing the first number of the VIN. Replace it with your VIN (minus the first number) by simply highlighting each letter on the right side and typing in your VIN. Then program back the chip and you’re done.
    StLouisCPhT also found that you only have to clear the VIN. (Make it "00" in the Hex portion.) When you power up the radio in it's new car, it will learn the car's VIN.
    Has anyone here tried this, I will over weekend
  8. #7
    Feb 2010
    WALES
    I've already given you your dump fixed, what's the problem????
    wbr
  9. The Following User Says Thank You to shooting For This Useful Post:
    NeilD (29th December, 2019)
  10. #8
    Dec 2019
    Default VIN
    wbr
    I dont have a problem, I'm inquisitive and I like to know how, you fixed the eeprom dump for me however I would of prefered to of done it myself, I just couldn't work out the two digit checksum or how it associated to the vin string, as the rest of the file is identical
    I will try blanking the lot including the check digits and see what the result in the eeprom dump is after ive plugged it in, if the USA guy is right I guess the check digit should match the ones you changed the bin to, that is if I get it to work at all
  11. #9
    Dec 2019
    Thank you Shooting
    I have today fitted the Bluetooth OEM upgrade and used the BIN file you corrected for me, I read the original radio eeprom and the check digits were indeed exactly as you had set them in my fixed file.
    Does anyone know what other information this file holds as far as options go, I can see it holds the tuned stations in the radio
    I want to enable USB on the radio and possibly DAB, I know I can send it away to be done for a cost, but would love to try and do it myself, I have access to globaltis and I now have a spare CD400
    Thanks all
  12. #10
    Mar 2016
    Hi, I need to chande to new VIN: WOLPD8EG4B8060745
    Can someone help me?
  13. #11
    Nov 2013
    Macedonia
    Quote Originally Posted by Mankyro View Post
    New vin + crc
  14. The Following 2 Users Say Thank You to Zann For This Useful Post:
    Mankyro (18th March, 2020), shooting (18th March, 2020)
  15. #12
    Oct 2019
    Hello there,
    There is a Cd400 tape and original bluetooth. Tape vin is programmed but bluetooth is not working. Do you need different programming for Bluetooth? Please hepm me. Thanks...
    VIN: W0LPE5EC9DG031422
    CD 400 P/N: 20983513
    CD400 RPO CODE: UZZ
    MANUFACTURE DATE: May 2011
    SW Date: 05.04.2010
    HW Date: 16.10.2009
    Bluetooth P/N: 13353284
    HW Date: 20.11.2009
    SW Date: 26.05.2010
  16. #13
    Feb 2010
    WALES
    Quote Originally Posted by yavuzalper View Post
    Hello there,
    CD400 RPO CODE: UZZ
    SW Date: 05.04.2010
    HW Date: 16.10.2009
    HW Date: 20.11.2009
    SW Date: 26.05.2010
    Here with New VIN and Checksums fixed too...
    wbr
  17. The Following User Says Thank You to shooting For This Useful Post:
    Zann (9th September, 2020)
  18. #14
    Oct 2019
    Do you need MDI and SPS for Bluetooth to work?
  19. #15
    Oct 2019
    wbr
