Audi A3 manual 2.0l 2009 4 cyl hatchback
Monday,09,December,2019,11:13:18:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WAUZZZ8P69A048979 License Plate:
Mileage: 98440km-61167mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 55 56
VIN: WAUZZZ8P69A048979 Mileage: 98440km-61167miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AB HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0H8FNH0U6
Coding: 0103000C180F0060
Shop #: WSC 01357 011 00200
VCID: 72EC018A6D3461D1EF-8026
2 Faults Found:
012691 - Intake Manifold Runner Control
P3193 - 002 - Open Stop outside of Valid Range
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 98449 km
Time Indication: 0
Date: 2019.11.28
Time: 20:09:43
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 19.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.065 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 98449 km
Time Indication: 0
Date: 2019.11.28
Time: 20:09:43
Readiness: 0110 0001
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0109
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 00003 329 177603
VCID: 75E63A96DC5A76E9CA-8020
3 Faults Found:
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Time Indication: 0
Date: 2019.11.28
Time: 22:15:08
Freeze Frame:
Count: 7
Count: 2
Count: 12800
Count: 320
Count: 43776
Count: 0
Count: 0
Count: 0
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Time Indication: 0
Date: 2019.11.28
Time: 22:15:08
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Time Indication: 0
Date: 2019.11.28
Time: 22:15:08
Freeze Frame:
Count: 7
Count: 2
Count: 12800
Count: 195
Count: 43776
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000068 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
1 Fault Found:
01336 - Company Data Bus for Comfort System
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 10
Mileage: 98396 km
Time Indication: 0
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008957476
Coding: 118E0F0780141380EF00000A4F00000000084E056406000300 2000000000
Shop #: WSC 06314 000 08192
VCID: 489883623B28BB0161-801C
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
3 Faults Found:
00988 - Lamp for Brake Light; Right (M10)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 233
Mileage: 90583 km
Time Indication: 0
Date: 2018.10.27
Time: 01:51:00
Freeze Frame:
ON
Voltage: 14.00 V
OFF
ON
OFF
OFF
ON
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 233
Mileage: 90583 km
Time Indication: 0
Date: 2018.10.27
Time: 01:51:00
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 196
Reset counter: 233
Mileage: 92480 km
Time Indication: 0
Date: 2019.04.22
Time: 22:07:00
Freeze Frame:
ON
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142413039303030344A55304C38503053
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_Airba01AURB4 001001
ROD: N/A
VCID: 499E8666E82242097E-801C
Subsystem 1 - Serial number: 34928RB4000044B0387J
Subsystem 2 - Serial number: 35028RB4000041AC89CU
Subsystem 3 - Serial number: 35128RB4000044B0C22A
Subsystem 4 - Serial number: 35228RB4000041AB7D4Q
Subsystem 5 - Serial number: 35547RB40000461CD5AV
Subsystem 6 - Serial number: 35647RB40000461CDBE%
No ASAM data for: "EV_Airba01AURB4" (AU35)
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000012
VCID: 78F833A20B480B81D1-802C
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 HW: 8P0 920 932
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2248H006002325
Coding: 0005128
Shop #: WSC 01286 386 00064
VCID: 71EE0E8668325AC916-8024
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K08919082E
Coding: E9831F061002020100
VCID: 3566FA965CDA36E90A-8060
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 233
Mileage: 90098 km
Time Indication: 0
Date: 2018.09.19
Time: 03:37:16
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 4382944E020E9859B4-8016
1 Fault Found:
00625 - Vehicle Speed Signal
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 29
Reset counter: 6
Mileage: 97286 km
Time Indication: 0
Date: 2019.08.22
Time: 22:08:25
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H18006 Serial number: AUX7Z0H8FNH0U6
Shop #: WSC 00137 211 56823
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0060
Coding: 0004148
VCID: 428C914A1D149151BF-8016
3 Faults Found:
01706 - Switch for Mirror-Adjust (E43)
008 - Implausible Signal
00943 - Heated Exterior Mirror; Driver Side (Z4)
00109 - Left Mirror Turn Signal Lamp (L131)
012 - Electrical Fault in Circuit - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 234 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5CD9EA8564691197-807E
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 50
Reset counter: 24
Mileage: 98422 km
Time Indication: 0
Date: 2019.11.24
Time: 21:25:26
Freeze Frame:
Voltage: 14.13 V
DU
Temperature: 28.0°C
RPM: 2163 /min
Speed: 57.0 km/h
Speed: 57.0 km/h
Count: 0
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1880200002186D2D8505488AC677
Shop #: WSC 00000 000 2088960
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
Component: AB2 SUBWOOFERBOXH30 0160
Revision: 00006 Serial number: 30659850321912
VCID: 3460C79257A02FE13D-8060
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
Coding: 0004148
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000013
VCID: 418E9E4618128A49A6-8014
2 Faults Found:
01291 - Rear Left Side Airbag Shut-Off Key Switch (E297)
011 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11101011
Fault Priority: 10
Fault Frequency: 0
Reset counter: 40
Mileage: 84776 km
Time Indication: 0
Date: 2017.09.03
Time: 01:36:18
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Priority: 10
Fault Frequency: 0
Reset counter: 40
Mileage: 84776 km
Time Indication: 0
Date: 2017.09.03
Time: 01:36:18
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H03 0270
Revision: 00H03000 Serial number: AUZ1Z3H3472153
Coding: 0110211
VCID: 3F8A98BE6EE6FCB9D0-806A
End-------------------------(Elapsed Time: 02:05)--------------------------
