Results 1 to 10 of 10
Hybrid View
    rola1971's Avatar
    Jun 2014
    Dublin
    Default PSA EDC17CP52 from robot gearbox to manual
    have car peuget boxer 2009 year
    orginal gearbox robotic guy put manual gearbox and this moment need turn off this robot from engine ecu.
    may be you help or have dump from ecu in manual gearbox
    ecu 0281016888
    51888308
    1039s41348
    rola1971's Avatar
    Jun 2014
    Dublin
    any news guy
    no solution for this?
    macinek102's Avatar
    Feb 2019
    PL
    the setting you make in BC not in ECU. download ALFOBD.COM install, find PEUGOT, then, active settings, and finally car configuration settings, and there you have a gearbox (not for Fiat 500). If you have questions, write to PM
    http://alfaobd.com/
    rola1971's Avatar
    Jun 2014
    Dublin
    it is engine ecu 100%
    need maps from manual gearbox
    macinek102's Avatar
    Feb 2019
    PL
    Your choice
    I already did that ( FIAT 500 ), and You?
    Sep 2016
    Poland
    change configuration in bcm not ecu.
    FILE SERVICE
    peko's Avatar
    Jan 2010
    Why you not use diagbox to made this job
    using manual configuration ...
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by peko View Post
    IT IS ONLY NAME peugeot
    it is fiat ducato
    it is fiat system
    rola1971's Avatar
    Jun 2014
    Dublin
    it is fiat ducato
    it is fiat system
    macinek102's Avatar
    Feb 2019
    PL
    Quote Originally Posted by rola1971 View Post
    it is fiat ducato
    it is fiat system
    So use alternative software for FIAT
