Bad DFLASH or bad reading of flash...
Here is good DFLASH and repaired EEPROM. Tested both and working...
Regards
Fellow members,This FRM has no communication after battery changed in car.
I have read a FRM Pflash, eeprom and Dflash, but Dflash seem to be empty?
How to go about?
use other Dflash dump and recode the FRM?
FRM3M E70 AHL
6135
9230433-01
hw 06 sw 12.20.00
Many thanks for help in advance!!
Regards
clauberty (7th May, 2020)
Problem solved! Maybe usefull to others with same problem..
Got a Pflash and eee dump with same sw and hw numbers from other forum and had to code frm again to car.
Don’t forget! Please press ‘thanks’ if helped!
how did you flash the files back to te frm???
If I was helpful DONT forget the THANKS and REPbutton
You just need to flash back Pflash and eee. Then reinstall in car and code it suitable tool.
Please don’t forget ‘thanks’ button if I helped!
Hi, I have a similar problem with the same numbers of you. I need the same files, you can put the good files for I write my frm3r Please
Thanks and good work!
