Mpps cable
Results 1 to 8 of 8
Thread: Mpps cable
    Dec 2019
    Default Mpps cable
    Hello guys.Can i flash golf 4 agu with mpps cable via obd?
    May 2017
    AGU = M3.8 = no for MK4 (or I never see one before) ... most need soldering, socket... PLCC or 29F200AB.
    On some A4... flashable but no read.
  3. The Following User Says Thank You to Lambda1 For This Useful Post:
    gpepes2012 (11th December, 2019)
    calibracbr's Avatar
    Aug 2015
    Moon
    You can only write with mpps by bench.
  5. The Following User Says Thank You to calibracbr For This Useful Post:
  6. #4
    Dec 2019
    Is there amother way for flashing via obd in me 3.8.3 agu ecu?
    May 2017
    no cant be flash via obd.
    need bench or desoldering.
  8. #6
    Aug 2012
    Quote Originally Posted by Lambda1 View Post
    u can flash obd but u need put 12v to pin 13 obd .
    not all cars has this connection in obd
    check plug before
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
  9. The Following User Says Thank You to icezero2010 For This Useful Post:
    gpepes2012 (15th December, 2019)
  10. #7
    Dec 2019
    Can i find this cable somewhere with instructions and pictures?
    [COLOR=rgba(0, 0, 0, 0.54)]
    [/COLOR]
    [/COLOR]
  11. #8
    Dec 2019
