Results 1 to 11 of 11
    Mooti's Avatar
    Nov 2018
    Default OCTAVIA 2,0TDI 110kW edc 17c64
    Octavia EDC 17c64 and I would like more power. My kess v2 only has the option to save the file, and the ori file wants it to download the original. How do I do that?
    Or unless someone has a file ready with stage1 ???
    2014. 110kW.
    Engine: R4 2,0L EDC
    HW Ver.: 04L907309D
    SW upg.: 04L906021DS 7544
    Installation: EDC17 CB.06.07.01 C50.00
    Northern europe
    If I remember correctly , not sure to be honest , this ECU's had to be patched for old Kess in order to be able to write. So not sure you can flash back. Try to read ecu with KTAG.
    Myjector's Avatar
    Dec 2017
    What sw version?
    You have Kess clone?
    Then you better ktag it
    AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
    FULL SWIFTEC AND EVC RESELLER
    FILE SERVICE FROM 8AM - 9PM 7/7
    BAPRO 4WD DYNO
    Aug 2018
    Nederland
    Default STG1
    Quote Originally Posted by Mooti View Post
    2014. 110kW.
    Engine: R4 2,0L EDC
    HW Ver.: 04L907309D
    PLEAS PM FOR PASSWORD AND THANKS MY
    no spam in sigs !!!
  5. The Following 2 Users Say Thank You to ecuworks For This Useful Post:
    Mooti (12th December, 2019), spitt (13th January, 2020)
    Northern europe
    Quote Originally Posted by ecuworks View Post
    You sure he can flash the file with his Clone Kess without bricking ECU ? I'm not so sure...
    Oct 2017
    Europe
    Yes he can do it with clone kess.Tested - works ok,just need ksuite 2.47
    Mooti's Avatar
    Nov 2018
    I have ksuite 2.08...
    If I upload this file, the car will start?
    My kess clone has only OBD write option, I don't have read option.
    If I do not load the file properly, can I do recovery?
    Northern europe
    If you don't have a backup of the ECU , anything you try with that version of the clone is risky.
    When working on such ECU is better to have a backup before you fool around. ... it's like that .. "you ~~~~ it , you pay it"
  10. #9
    Myjector's Avatar
    Dec 2017
    Buy cheap Ktag clone
    BAPRO 4WD DYNO
  11. #10
    Mooti's Avatar
    Nov 2018
    Does anyone have a connection description for connecting tricore kessv2?
  12. #11
    Myjector's Avatar
    Dec 2017
    Only KTAG (clone) can do tricore on EDC17C64
    Kess tricore not support it
    BAPRO 4WD DYNO
