Results 1 to 4 of 4
    Default ford focus instrument cluster delay
    2008 ford focus. when I start up car the instrument cluster comes on with all lights, engine,airbag,abs.etc. but for about 20 secs these lights stop on and rev counter,fuel guage and temp guage will not work, then after about 20 secs,everything goes fine. also I noticed electric windows will not work for the same time. this happens everytime the car is stopped and started up. 20 secs delay. can someone help with this fault as it seems to be a common problem, thanks
    doctore's Avatar
    Nov 2015
    Colorado Denver
    check wires behind dash
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    Quote Originally Posted by doctore View Post
    Just a update. Problem was ignition switch.
  4. The Following User Says Thank You to radiosolutions For This Useful Post:
    Meat-Head (16th December, 2019)
    Meat-Head's Avatar
    Weird could understand loosing on crank, but not 20 seconds delay
    #RUN DMC HOW BIASARRE
