Results 1 to 11 of 11
    Nov 2018
    Default Toyota - Blue film covering Solder joints
    Hello i was gonna edit km on this toyota but after removing the dash i see that this board looks like it has been repaired before. And over the eeprom i see this blue film/glue. I've never seen this before so im not sure how to remove it or what it really is.
    Anyone have experience with this before? Can i just use hot air over is and remove the chip? or will there be any problems?tundra.jpg
    Thanks in advance.
    Nov 2015
    Detroit
    Very poisonous that blue stuff
    Nov 2018
    Quote Originally Posted by BYTES View Post
    Any tips for removing it safely?
    frankrayk's Avatar
    Aug 2015
    42 52 41 5A 49 4C
    Quote Originally Posted by munkss View Post
    This blue material is original, clean with thinner solvent.
    If I was useful to you, thank you by pressing the thank you button .
  5. The Following User Says Thank You to frankrayk For This Useful Post:
    munkss (11th December, 2019)
    Nov 2018
    Quote Originally Posted by frankrayk View Post
    Thanks so much for the reply, are you talking about regular paint thinner or is there any kind of special i need to use to not damage the board?
    frankrayk's Avatar
    Aug 2015
    42 52 41 5A 49 4C
    That's right, I use to remove and then clean everything with isopropyl alcohol.
  8. The Following User Says Thank You to frankrayk For This Useful Post:
  9. #7
    Nov 2018
    Ok ill try with 100% acetone and qtips. and check if comes off. Thanks again
  10. #8
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    I use alcohol to clean blue glue of eeprom.
  11. The Following User Says Thank You to jomberykaso For This Useful Post:
  12. #9
    Cllau's Avatar
    Mar 2017
    where friends need me
    use a tweezer before cleaning and try gentle to remove as much you can, if you lucky may not need to use a cleaner, sometimes they come off very easy...
  13. The Following User Says Thank You to Cllau For This Useful Post:
    munkss (12th December, 2019)
  14. #10
    Nov 2018
    Quote Originally Posted by Cllau View Post
    Thanks for tips <3, i got the eeprom of no problem, but now i have other problem with coding, i made a new thread.
  15. #11
    Mar 2016
    Epoxy/conformal coating removal pens are cheap off Amazon. They contain tetrahydrofuran and can be refilled if you have a funnel with a tight fit.
