Results 1 to 7 of 7
    Oct 2016
    Poland
    Default bmw x5 e53 30d edc15c4 correct pinout
    I'm struggling to do bench a read with kessv2 clone 5,017 on bmw's edc15
    0281 010 314; 7 789 376
    i tried pins given in kess help, its worthless, also tried other ones i googled, help anyone?
    Regards Chris
    Dec 2009
    Attachment 674361Look at this
    May 2017
    Test with bootpin at 29fxxx.
    Oct 2016
    Poland
    Quote Originally Posted by Lambda1 View Post
    which kess cable should use then, and which bootpin is that (no info in kess help)
    115jtd's Avatar
    Mar 2019
    disconnect eeprom
    May 2017
    Normal K-Line Pinout... than set bootpin (ground for 6 sec)... bootpin 29fxxx you found in net.
  7. The Following User Says Thank You to Lambda1 For This Useful Post:
    kysioo (13th December, 2019)
  8. #7
    Oct 2016
    Poland
    i've done what i had 2do on car via obd , thx anyway
