Can somebody plese, help me to make DPF and pump off?
Dump attached:
Thanks!
Dump attached:
Thanks!
pass- PM
Thancks and reputation
Test and Report
tihiuvek (13th December, 2019)
Thanks for your help!
Unfortunately that is DPF remove solution and it is not working correctly!
Car is not going over 3000RPM and regeneration is present every few KM.
did you solve the problem with dpf off ???
thnx button..........rar pass pm
DPF OFF
DTCs has been deleted
Additive Pump Removed
INSTRUCTION
1.Reset particular filter soot counter
2.Delete all errors from the control unit
3.Make sure that all the DPF related sensor are connected
4.write the file to the control unit
5.Empty the DPF
Thanks but does not work!
File from ASC - not correct.
Checksum not corrected.
i have solution if you not solved this
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
No my problem is not solved!
Can you help?
Thanks!
hi please you pass
