need original file also
Hi guy, have any checksum for ecu denso SUBARU FORESTER ? For my customers must calculate dump... He have clone hw, not posible write without calculated CHSK ... Thank you for help... File moded DPF OFF...
Do not forget to THANKS !
SWIFTECH FULL
ECM Titanium FULL
KESS V3
AUTOTUNERS
B-FLASH
WINOLS
TOPDONE
AUTEL
FILE SERVISE .. web under construction
WinOLS5, custom files for diesel ECU
xanubysx
hi colleguo 3 chk not good mod flash file,calculated ok 3 chk
write test and report
thnx.....pass pm
this DPF off solution will create problems in the future.
pike
collegue i understand you only in your ori file chk repaired nothing more for dpf off thats your solution with that i have no connection ..... what's the problem now ???
here use with ck ok
pike
what are you doing you are just looking for chk repair nothing more, now what are you writing from dpf off solution, i don't understand you ??????????
open file from first message and see what changes are made if, of course, you understand something about this.
Pike I do not understand this .... :-) come on be a funny colleague, I just calculated the chaksum nothing more.and what else should I do ???? if he put a bad mod flash file then what do you think i'm guilty ??? he just asked for a chaksum repaired read and you better
Hi guy, have any checksum for ecu denso SUBARU FORESTER ? For my customers must calculate dump... He have clone hw, not posible write without calculated CHSK ... Thank you for help... File moded DPF OFF...Attached Files
you see read better that he did dpf off and i just need chk repaired for his car to turn on when he enrolls. Just don't philosophize as masters i didn't start this job now ..... if you can help him then do it and don't play someone
