Dear Friends
I need your help to install a used Hyundai Tucson 2017 SIM2K241 ECU.
I have the vehicle pin code and I also have the used ECU pin code that I am going to install.
What tool should I use to match this ecu in the vehicle and what would the procedure be?
thanks for your help
Can you post dumps + pins from them?
I have uncovered the used ecu and I will do the reading. Meanwhile, the requested image is published.
I wonder if there will be immo off for this ecu?
Please help me if possible immo OFF for this ecu SIM2K-241.
In any case I need the procedure to match the ECU to the vehicle.
