Here tested off
crisvenua2 (13th December, 2019), doctore (13th December, 2019), rafal (13th December, 2019)
my file is tested multiple times mate and i use this yesterday on Citroen C2, so check your car maybe have another problem
and why you need immo off??are you sure is immo problem?????
if you look on the internet there are more people like me who after using this file the fans are always running, it is a matter of configuration of the type of vehicle and components, your file is not valid for my car. With the original the fans do not turn on. My car is a Citroen C3, if the problem is immobilizer, I lost my keys, with the file I already tested a couple of weeks ago, the same as you started, but I had the fan problem.
try to change configuration on ECU in lexia not possible try with pp2000
you want virgin file?
Citroen C3 with AC have a different cooling fan controller and can't be immo off. Only option is to put virgin dump and configure it. In your case read pin code and program a new transponder. If you read your ecu flash post it and its possible to read pin
crisvenua2 (14th December, 2019)
the file does not pass, for all, the same as the "friend" lemans, does not work with cars with AC
here the forum is not a cafe, so be careful you post your problem on 3 or more forums and as you can see on 1 forum your threat is locked!!!
Join DateMar 2010
Posts166
83
Downloads8
Uploads2
pas word plz
