Results 1 to 9 of 9
    PSAcars's Avatar
    Oct 2015
    HOME
    Default 2016 Jetta vw11 airbag clear please
    Hello to all. Please clear this vw11 whit spc56ap54. Data flash read by upa-s. Here on DK I found other threads about spc56 and there was info about that upa can not write this mcu with clear file, is this true, can someone confirm?
    here is your file thanks
  3. The Following User Says Thank You to bahlawi For This Useful Post:
    PSAcars (14th December, 2019)
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Result about clear if clear is OK, I will upload next week, about the spc560ap54 my upa has no problems writing.
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. bahlawi file is NOT OK. If you have other file or someone other can help me please. About curtains I dont have them now but I will put new.
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Someone can help??
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Whit this file no cler comand to ecu can be made. Need other file, please.
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    Write original crash dump and check for internal fault
  9. The Following User Says Thank You to AB4S For This Useful Post:
    jnc20 (18th December, 2019)
  10. #8
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Not good news. With original dump have internal error, B200000 and can not clear error with vcds.
  11. #9
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Any nwes. Some one
