Results 1 to 2 of 2
    McDowell's Avatar
    Feb 2019
    Zamunda
    Default Seat Leon 2010 BCM lights fault
    Hello mates,
    I am having problems with fog , position and reversing lamps.
    Does anyone know which is the faulty electronic componnt on the board? or have schematics,pinout for doing my research?
    Thank you so much in advance
  2. The Following User Says Thank You to McDowell For This Useful Post:
    Meat-Head (5th January, 2020)
  3. #2
    Meat-Head's Avatar
    So sorry, didn’t see this before
    VAUGE MODE ON:-
    under hood fusebox are two fuses either 30 or 40 amp.
    SUB VAGUE MODE ON:-
    one fuse is a BIG fuse, which does abc lights
    the other fuse is a smaller fuse which does xyz lights
    SUB VAGUE MODE OFF:-
    its the smaller fuse the pins burn, and damage underbonnet fusebox
    VAGUE MODE OFF:-
    SUMMARY:-
    Change under bonnet fuse box (its just brass and plastic) TAKE PHOTOS FIRST
    Then look for the fault.
    cost from dealer here in uk in hand is £200 +/- £10
