Results 1 to 10 of 10
    Feb 2018
    Default General Questions on Kess / Ktag and EDC16
    Hello guys,
    i am interested in ecu data and the way how everything works.
    i am a newbie and so my questions will be very Basic.
    i already have a kess v2 and have read data of a edc16, i think nearly 2mb data size.
    before i come to the Point when writing back data to my ecu, i wanted to generate a Full ecu read That makes it possible to Clone a 2nd Hand ecu That Fits To my ecu like the Original does.
    is this possible With kess and the way i did it? (Reading through CAN)
    begi1's Avatar
    Jun 2018
    Bosnia and Herzegovina
    If you want clone ECU, you need full read and full write ( mpc, flash, eeprom). Kess cant do it. You need KTAG, or other tool.
    If I helped you, dont forget click Thanks and Rep button. Thanks
  3. The Following User Says Thank You to begi1 For This Useful Post:
    maxtor911 (17th December, 2019)
    Feb 2018
    hello begi1,
    thanks for your fast and detailed answer, this is exactly what i wanted to know.
    in this case i will choose a ktag.
    what exactly did i read with my kess? mpc, flash or eeprom?
    regards
    chrisimerk's Avatar
    Dec 2018
    England
    you read only flash with kess even that is a partial read
  6. The Following User Says Thank You to chrisimerk For This Useful Post:
    maxtor911 (18th December, 2019)
    Feb 2018
    hello chrisimerk,
    thanks for info :-).
    what belongs to kess reading:
    where is the difference between reading in „CAN“ and „KLINE“?
    does it end in having identical data?
    regards
  8. #6
    begi1's Avatar
    Jun 2018
    Quote Originally Posted by maxtor911 View Post
    hello chrisimerk,
    regards
    Don't worry about kline and can..... Try with can if working, reading and writing speed will be faster, kline is slower... But always flash be same.
  9. The Following User Says Thank You to begi1 For This Useful Post:
  10. #7
    Feb 2018
    hello begi1,
    is it necessary to generate a full backup by bdm before working on the flash dump or not?
    regards
  11. #8
    begi1's Avatar
    Jun 2018
    hello begi1,
    regards
    full backup always recommend and much safer, but is not necessary
  12. The Following User Says Thank You to begi1 For This Useful Post:
  13. #9
    chrisimerk's Avatar
    Dec 2018
    England
    depends on what type of ecu your working on some are safe to do over obd without full back up hoping that you have over 12v power supply your laptop battery is charged and the file your writing is ok but ecus that are locked, Tprot active then you have to have a full bdm back up there ok to read but never flash back without full backup
    but remapping any ecu there is always a risk so if your not right sure then best bet would be full backup
  14. The Following User Says Thank You to chrisimerk For This Useful Post:
  15. #10
    Feb 2018
    thanks for info.
    it is a edc16 ecu, car daily driven.
    i think i will start with a bdm full read and clone a 2nd hand used ecu, so i always have a working ecu as backup.
    regards
