Results 1 to 7 of 7
    Mar 2013
    Default Audi A3 2.0 TDI PPD DPF Problem
    Hello to everyone, I have this car already defapped and I can't recognized the right ori file, but the problem is that I have the fap error on the dashboard and the file is "ok", so I think the problem is the temperature and the differential sensor, and I need the file tested with all off if is possible, i attach the actual file and the ID, thanks a lot.
    Write your DTC
    Oct 2018
    have you resetted dpf bevore write dpf off file?
    Mar 2013
    this is the problem, i do not write the file, the file is already in the ecu and I can't find the original file of this ecu
    Mar 2013
    I've found the ori file, but he ever ask for regeneration..
    Oct 2018
    write org file in ecu
    reset dpf
    write dpf off file in ecu
    dive..should be ok
    waldi1979's Avatar
    Dec 2010
    Diff press sensor must be right.
