Results 1 to 11 of 11
    Jan 2016
    Jumping Around the globe
    Default Seat Technisat ULSECD radio code needed
    I tried getting the code with carprog but somehow it always fail to get code. I get "read error"
    But if i read the eeprom on carprog as 24c16 it does read correctly. I have no idea why carprog doesnt let us upload the file and get it decoded.
    My dump is uploaded if anyone can help with the code, or if anyone knows why carprog is failing it would be great
    sonices's Avatar
    Because code address changed in wrong way
    Jan 2016
    you mean someone before me messed around with this unit?
    sonices's Avatar
    Try this dump maybe it will be ok. Can you make photo of label?
  5. The Following 2 Users Say Thank You to sonices For This Useful Post:
    Locker (21st December, 2019), Shmee23 (9th January, 2023)
    Jan 2016
    I wrote your dump on the eeprom, and tried to read the code again with carprog, got same error. Didnt try to power the radio (i unsoldered the eeprom)
    uploaded a photo of the label
    sonices's Avatar
    I had same radio i think your dump that i modified will work, maybe not on table but in car must work.
    Why you read with Carprog when i have sent you dump with code?
    Jan 2016
    Because the eeprom is unsoldered and wanted to check what is the issue with my carprog, to check if my file was wrong or i have an issue with carprog.
    i will solder it back and try with your code
    sonices's Avatar
    Ok , understanded now. Please report
  10. #9
    Jan 2016
    It worked without even asking about a pincode.
    Thanks!
  11. #10
    sonices's Avatar
    Thats good , but please tell me you have tried on bench or in car?
  12. #11
    Jan 2016
    On bench for now. We removed form the car couple days ago, client will be back tomorrow to fit it back
  13. The Following User Says Thank You to Locker For This Useful Post:
    sonices (24th December, 2019)
