Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 55
  1. #16
    DiegoStud's Avatar
    Aug 2019
    Away so can't see your file but 194409 onwards is also UACC_ESBNormVal_C like 1F1ED9. So make the same change there from 200 to 255 as you have done at 1F1ED9.
  2. The Following 2 Users Say Thank You to DiegoStud For This Useful Post:
    Meat-Head (28th December, 2019), vwstuff (29th December, 2019)
  3. #17
    Jan 2012
    Got It Thanks
  4. #18
    Jan 2012
    I fact I need another formule what is the best one ?
    Log done at 2750 Mbars request
  5. #19
    DiegoStud's Avatar
    Aug 2019
    You must have an intercooler the size of a patio door sitting in a bath of LN2.
    Before you go down the formula changing route, have you considered the possibility you may have a boost leak? Or that your MAF is lying?
    I mean let's do a bit of quick maths- MAF/PR/CC= rough VE calculation.
    @1500rpm VE is around 100%. On the optimistic side but there's a large volume of air being filled in the intake system.
    @2500rpm VE is about 130%. Not happening in this universe at least.
    @4850rpm VE is about 95%. From an 8v TDI? Whoever ported out your head is a living legend. At this point also there is no delay in boost pipe expansion etc to account for excess airflow, in fact boost is dropping.
    According to MAF your peak flow is approx 700kg/hour and remains thereabouts from 3600rpm until 5061rpm.
    To get that sort of flow plausible at 2750mbar your post intercooler air temperature would need to be about -5 degC which is.... implausible.
  6. The Following User Says Thank You to DiegoStud For This Useful Post:
    Meat-Head (5th January, 2020)
  7. #20
    Meat-Head's Avatar
    Quote Originally Posted by DiegoStud View Post
    As your off on one, for use leechers, can you tell us if the bath has to be cast iron or will
    A regular plastic one do please? Can you tell us if the intercooler can be the
    same thickness as a patio door, or does it need to fit the bath?
    AWESOME post, although some DK members would not fully understand it.
  8. The Following User Says Thank You to Meat-Head For This Useful Post:
    DiegoStud (6th January, 2020)
  9. #21
    DiegoStud's Avatar
    Aug 2019
    What the bath is made of is unimportant, but the patio doors must be 1970s metal framed sliding ones not these small new cheap things with more plastic than glass.
  10. The Following User Says Thank You to DiegoStud For This Useful Post:
    Meat-Head (8th January, 2020)
  11. #22
    Jan 2012
    Will test a new MAF asap
  12. #23
    Jan 2012
    I'm still trying to find sig_qDIAScale_C for max iQ any idea ?!!
    Through pressure test I found a leak when pipe mouving ...
    I'm waiting for some parts .
    I attached a pic of my new intercooler I guess, some body work is mandatory.
    I just purchase a Metalwork for Craftsmen book for this purpose.
  13. The Following User Says Thank You to vwstuff For This Useful Post:
    DiegoStud (8th January, 2020)
  14. #24
    DiegoStud's Avatar
    Aug 2019
    Nice pic, it would fit in a bath rather well
    Well done finding the leak, your turbo will thank you for it.
    If sig_qDIAScale_C is not 1C12AE then it's 1C12B6.
  15. The Following 2 Users Say Thank You to DiegoStud For This Useful Post:
    Meat-Head (8th January, 2020), vwstuff (9th January, 2020)
  16. #25
    Jan 2012
    I'm not sure for the two address stock formule ( 39 ) is b/256*a so factor is 255/70 =3.64
    and both values for 1C12AE and 1C12B6 are 0.037
  17. #26
    DiegoStud's Avatar
    Aug 2019
    Yes but IQ values have a factor of 0.01 therefore 255/7000= 0.0364.
    Why the original figure is 0.037 rather than 0.0364 is not a question to which I have found a satisfactory answer.
  18. The Following 2 Users Say Thank You to DiegoStud For This Useful Post:
    Meat-Head (9th January, 2020), vwstuff (9th January, 2020)
  19. #27
    Meat-Head's Avatar
    Yes but IQ ..........I have found a satisfactory answer.
    Think you meant to say you have an iq higher than einstine, do you have the lottery numbers to hand
  20. #28
    Jan 2012
    So With no boost leak and new MAF : logs attached.
    I tried to change MAF Formular from 19 to 8 with a = 80 to archive 2040 ( 0.1*a*b) with no succes .
    I wonder if there is two UACC_ESBFormular_C maps ?! Formular 8 is NOT take into account by the ECU.
    And also my iq is over 85 ....well some think is wrong
    Will try to set both 1C12AE and 1C12B6 with same factor values ?
    File attached
    Albert IQ is 160 ...I'm stuck at 85 ?
  21. The Following User Says Thank You to vwstuff For This Useful Post:
    Meat-Head (17th January, 2020)
  22. #29
    DiegoStud's Avatar
    Aug 2019
    Yes in your file you have two UACC_ESBFormular_C- 1941D8, 1F1CA8.
    IQ stuck at 85- if you want to log more than 85 why have you only scaled until 85? Would not 100 with 0.0255 make more sense?
    I wonder how wise it is to be trying to edit MAF and IQ diagnostic limits at the same time, sounds like you are losing track of what's going on. Modify one at a time, log and confirm.
    With regards to the log itself- a little smokey maybe?
    What would you like to know? Comparing Lambda to MAF well provides an empirical flow model for the engine. Do I think MAF is still high? Possibly so, and with a larger intercooler on the way the disparity will increase. However as I've already commented on, it's very difficult to try to analyse MAF data during heavy transient response, no single figure of expected MAF can be given to correlate with MAP unless you are willing to run simluations or plug the figures into some horrible equations (Heywood C14).
    Considering the above and the fact the majority of the log covers a turbo spooling on an accelerating engine and the diagnostic air flow limitation occurs for just 2 seconds, the reason is clear why I'm not keen on MAF for smoke limitation purposes.
    Energy conservation is more Newtonian than Einsteinian
  23. The Following 3 Users Say Thank You to DiegoStud For This Useful Post:
    Meat-Head (17th January, 2020), Prodrive (9th February, 2020), vwstuff (18th January, 2020)
  24. #30
    Jan 2012
    Thanks for UACC_ESBFormular_C
    My car smoke visibly at 0.9
    I don't plan to Inject more than 75-80 IQ
    MAF is for testing airflow of my UGLY inlet manifold Prototype (build in process pict attached )
    In fact I'm try to understand what is the best way to calculate smoke map and how to process ? I know i'm slow ....
    And also I wish to archive a constant boost from 2000 to 5000 rpm at 2750 Mbars to lower final ergt.My goal is below 800 °C
    I notice 2 maps 1EB4CE - 1EB716 and wonder if they act like a limiter or this is simply engine efficiency fail down ?
    Speed of light being a constant, with time and length different… don’t ask Newtown about that
  25. The Following 2 Users Say Thank You to vwstuff For This Useful Post:
    DiegoStud (18th January, 2020), Meat-Head (20th January, 2020)
