Page 1 of 4 1234 LastLast
Results 1 to 15 of 55
    Jan 2012
    Default EDC16 REMOVING MAF DIAG LIMIT AT 1275
    I found :
    UACC_RSigBlkGrp_MAP 1F28A8
    UACC_ESBFormular_C 1F1CA8
    UACC_ESBNormVal_C 1F1ED9
    UACC_ESBSigNr_C 1F210A
    But I wonder where are located :
    sig_qDIAScale_C
    sig_qDIAOffset_C
    And how to process
    I'm stuck !!!!
    DiegoStud's Avatar
    Aug 2019
    1C12AE- Sig_qDIAScale_C
    1C12AC- Sig_qDIAOffset_C
  3. The Following 2 Users Say Thank You to DiegoStud For This Useful Post:
    Meat-Head (26th December, 2019), vwstuff (22nd December, 2019)
    Jan 2012
    Quote Originally Posted by DiegoStud View Post
    Thanks a lot Diego
    Jan 2012
    So : b/4*a*0.1
    This is 255/4 *200*0.1 = max at 1275 Mg/Str
    1C12AE- Sig_qDIAScale_C value on my car is 0.037
    but : (255/4)/200 *0.1 = 0.032 what is wrong ?!
  6. The Following User Says Thank You to vwstuff For This Useful Post:
    DiegoStud (24th December, 2019)
    DiegoStud's Avatar
    Aug 2019
    Your welcome, although they are not what you require.
    Signal 258 is AFSCD_mAirPerCyl__mAirCyl_DLen1 therefore you need:
    1C11C6-Sig_mDIAScale_C
    1C11C4- Sig_mDIAOffset_C.
    Including modification of NormVal you should be able to read 1625mg/stroke. Beyond that you need to change formula.
    Edit: My bad-
    1C118A- Sig_mAirCylDIAScale_C- 0.02
    1C118A- Sig_mAirCylDIAOffset_C- 0
    255/(1275*10)= 0.02
  8. The Following User Says Thank You to DiegoStud For This Useful Post:
    vwstuff (23rd December, 2019)
  9. #6
    Jan 2012
    Is 1625mg/stroke ( a=255) enough for a 2 liters with a gtb1756 ?
    1C1188 for Sig_mAirCylDIAOffset_C
  10. The Following User Says Thank You to vwstuff For This Useful Post:
  11. #7
    DiegoStud's Avatar
    Aug 2019
    Assuming you want a bit of extra scope to check for boost leaks, 1625mg would be fine for about 3200mbar boost. Plenty.
    Remember to modify Sig_mAirCylDIAScale_C to 0.0156.
  12. The Following User Says Thank You to DiegoStud For This Useful Post:
  13. #8
    DiegoStud's Avatar
    Aug 2019
    The following signals are dependant on Sig_mAirCylDIAScale_C, therefore the complete job would also require looking up these signals in UACC_ESBSigNr_C and modifying their respective NormVals also.
    300 "AirCtl_mDesVal__mAirCyl_DLen1"
    428 "AFSCD_mAirPerCyl1__mAirCyl_DLen1"
    429 "AFSCD_mAirPerCyl2__mAirCyl_DLen1"
  14. The Following 2 Users Say Thank You to DiegoStud For This Useful Post:
    Meat-Head (26th December, 2019), vwstuff (26th December, 2019)
  15. #9
    Jan 2012
    My goal is afr calculation ;
    smoke limitation via lambda seen to be not efficient ?!
  16. #10
    Meat-Head's Avatar
    Wowsere deigostud, your amazing, part of the Spanish Inquisition and you can speak
    Numbers and smoke, well done
  17. #11
    Jan 2012
    Another fan
    Finaly i'm not able to do it ... some think is wrong ?
  18. #12
    DiegoStud's Avatar
    Aug 2019
    Thanks Meat-Head!
    Smoke limitation by lambda is not what it sounds like on these engines. Lambda is a calculated mAirPerCyl value based on airflow rather than using the lambda sensor directly, which is an incredible disappointment I know.
    So in other words it's as efficient as your MAF.
    The lambda sensor is used for long-term adaptation in EGR and FMA correction, regulating O2 concentration in the cat/DPF and also to regulating post injection.
    In a way, view smoke limitation as controlling the fuel burned in the cylinder and the lambda controlling from the exhaust valves onwards.
    With the the diagnostic limits raised though you might be able to log and make you own calculations. From my own calcs if you are still around 2850mbar you shouldn't really be that much further beyond 1275mg.
  19. The Following 2 Users Say Thank You to DiegoStud For This Useful Post:
    Meat-Head (28th December, 2019), vwstuff (26th December, 2019)
  20. #13
    Jan 2012
    Yes really disappointment regarding the lambda sensor working condition on edc16 ....
    My diagnostic limits raised are NOT working properly as mentionned where I'm wrong ? !
  21. #14
    DiegoStud's Avatar
    Aug 2019
    194409-Another block of NormVal that needs changing- I'm assuming it has been forgotten as NormVals for 24,25 and 26 are changed and the Formular nearby has been changed to account for boost limits.
    Give that a try and report please.
    Beyond that it's starting to get difficult and I'll have to ponder I little further- I can see you have made changes to MAF SRC which might help beyond 4000rpm.
    Edit: P.S- having RPM and MAF together in one log would be great to make some calculations
  22. The Following 2 Users Say Thank You to DiegoStud For This Useful Post:
    Meat-Head (28th December, 2019), vwstuff (28th December, 2019)
  23. #15
    Jan 2012
    Sorry i'm confuse : what do you mean by 194409 ?
    According to my vcds version and UACC_RSigBlkGrp_MAP I need to change on UACC_ESBNormVal_C : three times : blocks 10, 44 ,133 value 7 and block 45 value 327 ! ?
