Results 1 to 7 of 7
    Jun 2019
    Default I NEED SOME HELP
    hi
    i have problem with ecu PEUGEOT 206 , 1.4 IAW 1AP.81, 2002 year ... car are normal working , and then stoped working and i can't now start the car and i can't a cconect diagnose with ecu ... please have anyone idea what is the problem ???
    please help
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by chokscan View Post
    hi
    please help
    i don't know about the others here but this black letter is a test for my eyes...... i am starting to lose my vision.....
    first check your fuses....
  3. The Following User Says Thank You to Panathaole For This Useful Post:
    chokscan (27th December, 2019)
    Jun 2019
    80768014_2552818505004219_6795045296322641920_n.jpgI check all fuses and relay and Check all power supplies to engine ecu,grounds too with test lamp
    i check all ., and all is OK power supplay
    Gdansk Poland
    did you check bsm ?? Maybe wires. Ecu + and - when communication is lost ??
    Jun 2019
    Jul 2017
    Serbia
    If PP2000 connects only to ABS and no communication with any other module then your problem is in BSI. Check VAN communication wires to and from BSI.
    May 2011
    Czech Republic
    look at the ignition coil, a unit fell from it, it went into the wiring
