Would anybody be so kind to give a hint how to access MIB2 STD units using Telnet?
I'm familiar with Harman units, I have a broken MIB2 Skoda Bolero here (constant reboots within a minute after turning on) and I'd like to take a look at it.
Connecting the UART TTL adapter to RX/TX pins as known with the Harman units I get just some unreadable log stream which cannot be stopped. So there must be some trick but I can't get it. I was given just a hint that desoldering the eMMC is no longer necessary and the unit can be entered other way...
Thanks in advance!
The unit is Delphi, so it should be possible.
I have heard the Technisat or Preh units are the toughest to crack...
I can help write PM
I can help
Good morning
Have you had any luck with the unit ? im trying to do the same
I've posted the full way to unlock but you need whatthefec.exe to patch out the fec
MIB 1/2 Solution
CP-OFF, Activation CarPlay Android auto map care, US/EU conversion
WhatTheFec, Advanced Green Menu
catalinosonesti (9th June, 2020)
Всем привет. У меня есть схема подключения чипа eMMC к внешнему USB-кард-ридеру для слива дампа. Затем я сделал резервную копию прошивки с помощью утилиты Win32 Disk Imager. Есть ли у кого-нибудь информация, что делать дальше?
catalinosonesti (30th August, 2020)
Какой маг technisat
Hi everybody,
Can someone help me with MIB2 STD nav Delphi MST_EU_VW_P0639D, unit went black screen with fun speening after firmware P0891D update editing the installation manager to change the variant. Unit finished the firmware update restarted and screen went black with fun speening. I have made backup with script for Delphi solution for Carplay. So is there any way to revive the unit connecting with Rx Tx serial connection or if you can share with me the EMMC reading pinout on the board i will be very greatfull.
Thanks in advance.
Hello!
My English is a little bit bad, but I'm going to try.
I have a Delphi mb2 unit and tried to patch but something went wrong and now, my unit, is not reading SD card and USB. I've been reading that the solution is reading and writting emmc, but I don't have experience. Who anybody help me?
Thank you in advance!
