We have swapped a 1.9 polo engine into another vehicle and wish to immobiliser off, what is the procedure for Bosch 028 906 021 dk ECU please?
Thanks!
Thanks!
you need read out eeprom ...think was 24c04 on this
yes its 24c04 eeprom and its as simple as changing few values to 60
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
Do I have to remove EEPROM from the board?
if you dont have a soic8 clip then yes you will have to desolder it from board
TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
SPECIALISE IN TUNING DIESEL ENGINES
(DEMON DEVELOPMENT)
IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
Heat it up with hot air gun and just lift it
You must desolder memory b58253 and add the post.
ps. You must buy memory 24c02 becouse b58253 is not program if you do not have goood programer.
just get a programmer and a soic8 clip then you dont have to desolder the eeprom will make life much easier
(DEMON DEVELOPMENT)
As stixo said, b58253 cannot be rewrite. See if your memory is 24C02 or b58253. After desoldering the eeprom and reading, if the eep is 24c02, you can modify some values from 33 to 60 and get immo off.
If the memory is b58253, find a 24c02 from ST or atmel(the best) and write modified eeprom and solder back. Always remember and mark the position of the eeprom before desoldering it.
Ok, so what programming tool do I need? Not done much board work since doing the old Playstation copy disc work back in the 90's .......
