Results 1 to 11 of 11
Hybrid View
    Feb 2010
    Lithuania
    Default BMW 120 edc17cp02 errors
    Hi, have Bmw 120d 2007 edc17cp02 1037389229 with errors.
    Read boot with kess2
    004011 DDE. Exhaust backpressure sensor before particular filter signal
    004E1E DDE. Swirl-valve controller, position sensor signal
    Today tested couple solutions, but nothing worked
    Who could help to remove only errors. PLEASE
    Feb 2010
    Lithuania
    Hi, no solutions for this bmw ?
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    Try this file, only these 2 errors...
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
  4. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    darius89 (31st December, 2019), morgano (31st December, 2019)
    Feb 2010
    Lithuania
    Thanks for help, but have same errors.
    Car is out with unsolved problem.
  6. #5
    bobolin4o's Avatar
    Apr 2010
    Quote Originally Posted by darius89 View Post
    If the car is still there - check with this file, i was made an mistake.
  7. The Following User Says Thank You to bobolin4o For This Useful Post:
    darius89 (2nd January, 2020)
  8. #6
    Feb 2010
    Lithuania
    Hi, car came back, loaded your new file and made test drive. ( dpf pressure sensor and swirl motor disconnected )
    Now have 4 errors
    4DFF Swirl valve controller, position control
    4E09 Swirl valve plousibility
    4D03 Exhaust back pressure sensor
    4E0F Swirl flaps plousibility
    Does anybody have solution ????
  9. #7
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    I have solution
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  10. #8
    Mar 2018
    Serbia
    Try this file, cs ok..
    If i help u, please use thanks and reputation button..
    on forum i always help for free, outside forum if u need quickly and good file service contact me on skype..
  11. The Following User Says Thank You to cupsi For This Useful Post:
    darius89 (8th January, 2020)
  12. #9
    jurebv's Avatar
    Dec 2017
    Croatia
    SWIRL off + dtc off
    Best Regards
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
  13. The Following User Says Thank You to jurebv For This Useful Post:
  14. #10
    Feb 2010
    Lithuania
    Quote Originally Posted by jurebv View Post
    SWIRL off + dtc off
    Best Regards
    Could you send pass
  15. #11
    Feb 2010
    Lithuania
    SWIRL off + dtc off
    Best Regards
    Hi, looks like second solution works. have
    0000 Unknown error
    But no MIL on dash and no limp .
    Will make test drive and let you know
    THANKS
