HELP CAS3 MINI
Results 1 to 11 of 11
Thread: HELP CAS3 MINI
    May 2015
    Default HELP CAS3 MINI
    HOLA LUEGO DE PROGRAMAR CAS3 CON ISTA P SE QUEDO MUERTO NO DA CONTACTO NI COMUNICA CON CAS.
    CAS61.35-9217853-01
    5WK4 9515ABR
    MICRO MC9S12XDP512
    0L15Y
    ADJUNTO LECTURA FLASH Y EEPROM
    AGRADEZCO AYUDA.
    HELLO THEN PROGRAMMING CAS3 WITH ISTA P STAY DEAD DOES NOT GIVE CONTACT OR COMMUNICATE WITH CAS.
    CAS61.35-9217853-01
    5WK4 9515ABR
    MICRO MC9S12XDP512
    0L15Y
    FLASH AND EEPROM READING ASSISTANT
    THANK YOU HELP.
  2. The Following User Says Thank You to guzman For This Useful Post:
    racuna (7th January, 2023)
  3. #2
    Aug 2015
    Germany
    new flash, manually fixed eep pls try and report
  4. The Following 4 Users Say Thank You to Chriz123 For This Useful Post:
    guzman (2nd January, 2020), lion0304 (18th December, 2020), max72 (22nd March, 2020), Stelaras26 (2nd January, 2020)
  5. #3
    May 2015
    Hi friend it worked perfectly, thank you very much.
    hola amigo funciono perfectamente, muchas gracias.
  6. The Following User Says Thank You to guzman For This Useful Post:
  7. #4
    Junior Member john chan's Avatar
    Dec 2017
    CA
    good work
    CAS61.35-9217853-01
    5WK4 9515ABR
    MICRO MC9S12XDP512
    0L15Y
  8. #5
    Dec 2017
    CA
    May I have the password for extraction of the rar file please?
  9. #6
    Dec 2017
    CA
    Quote Originally Posted by guzman View Post
  10. #7
    Dec 2017
    CA
    Quote Originally Posted by Chriz123 View Post
  11. #8
    Aug 2015
    Germany
    For what do you need it ?
    The eeprom won’t match to your car
  12. The Following User Says Thank You to Chriz123 For This Useful Post:
    john chan (9th January, 2020)
  13. #9
    Dec 2017
    CA
    I see, Thank U.
  14. #10
    Junior Member max72's Avatar
    Hungary
    Password for extraktion please::4
    Thank you
  15. #11
    Nov 2021
    Hello everyone
    Would someone have the pinout for the MC9S12XDP512 MCU with UPA?
