Results 1 to 14 of 14
    Jul 2019
    Default Audi A6 2011 messed up after screen replacment.
    Good morning. and a happy new year.
    Audi a6 2011 bloke which one called himself a car ''electrician'' mesed up a car.
    multimedia screen goed blank, so car goed for a screen wires replace.
    and comed back in a total mess.
    blowed fusses, all comfort stuff things aint working.
    Did a scan with VCDS and its just to much faults.
    can somebedy take a look to the scan file and just point me to the right direction where to start.
    Thanks.
    Monday,30,December,2019,18:20:23:00007
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 18.9.0.2
    Data version: 20180927 DS296.0
    www.Ross-Tech.com
    VIN: WAUZZZ4G8CN011647   License Plate: LY11KMU
    Mileage: 114926km-71411mi   Repair Order: audi 2011 supista
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 1B 1E 20 22 26 28
              2E 30 34 36 3B 3C 3D 3E 40 42 44 46 47 48 52 53 55 56 57 5B
              5F 62 69 6C 6D 6F 72 7F 81 82 84 85 88 89 8A 8B 8C 8D 8E 8F
              A4 A9 AC BA
    VIN: WAUZZZ4G8CN011647   Mileage: 114926km-71411miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: Cannot be reached 0100
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: Cannot be reached 0100
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: Cannot be reached 0100
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Cannot be reached 0100
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    1B-Active Steering -- Status: Cannot be reached 0100
    1E-Media Player 2 -- Status: Cannot be reached 0100
    20-High Beam Assist. -- Status: Cannot be reached 0100
    22-AWD -- Status: Cannot be reached 0100
    26-Auto Roof -- Status: Cannot be reached 0100
    28-HVAC, Rear -- Status: OK 0000
    2E-Media Player 3 -- Status: Cannot be reached 0100
    30-Special Function II -- Status: Cannot be reached 0100
    34-Level Control -- Status: Cannot be reached 0100
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: Cannot be reached 0100
    3D-Special Function -- Status: Cannot be reached 0100
    3E-Media Player 4 -- Status: Cannot be reached 0100
    40-AC Compressor -- Status: Cannot be reached 0100
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    48-Seat, Rear, DS -- Status: Cannot be reached 0100
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    57-TV Tuner -- Status: Cannot be reached 0100
    5B-Seat,Rear,PS -- Status: Cannot be reached 0100
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    69-Trailer -- Status: Cannot be reached 0100
    6C-Back-up Cam. -- Status: Malfunction 0010
    6D-Trunk Elect. -- Status: Cannot be reached 0100
    6F-Centr. Conv. II -- Status: Cannot be reached 0100
    72-Door, Rear Right -- Status: OK 0000
    7F-Inform. Electr. II -- Status: Cannot be reached 0100
    81-Gear Shift -- Status: Cannot be reached 0100
    82-Heads Up Display -- Status: Cannot be reached 0100
    84-Night Vision -- Status: Cannot be reached 0100
    85-On Board Cam. -- Status: Cannot be reached 0100
    88-Multicont. Seat Driver -- Status: Cannot be reached 0100
    89-Multicont. Seat Pass. -- Status: Cannot be reached 0100
    8A-Multicont. Seat Rear,DS -- Status: Cannot be reached 0100
    8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
    8C-Hybrid Battery -- Status: Cannot be reached 0100
    8D-Multicont. Seat Rear,PS -- Status: Cannot be reached 0100
    8E-Image Processing -- Status: Cannot be reached 0100
    8F-Pretens. Frt Left -- Status: Cannot be reached 0100
    A4-Armrest -- Status: Cannot be reached 0100
    A9-Struct. Borne Sound -- Status: Cannot be reached 0100
    AC-Reductant Control -- Status: Cannot be reached 0100
    BA-Motor Mounts -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 F    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0004
       Revision: 53H37---
       Coding: 0A254012052601020000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
       ROD: EV_ECM30TDI0114G0907401F.rod
       VCID: 2643409959E70A7A8F-8072
    2 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
              Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine speed: 753.50 /min
                        Normed load value: 24.7 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 82 °C
                        Intake air temperature: 26 °C
                        Ambient air pressure: 1020 mbar
                        Voltage terminal 30: 13.560 V
                        Unlearning counter according OBD: 40
                        Cruise Control System (CCS): switch position-Bits 0-7: 0
                        Cruise Control System (CCS): status-Bits 0-7: 12
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise Control System: specified speed: 0.00 km/h
                        Engine control module reset status-Bits 0-7: 0
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
    5608 - No Communications with Steering Angle Sender (G85)
              U0126 00 [039] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine speed: 751.50 /min
                        Normed load value: 24.3 %
                        Voltage terminal 30: 13.540 V
                        Limitation: accelerator pedal: 0.0 Nm
                        CAN status - engine control module-Bits 0-7: 0
                        CAN status - transmission control module-Bits 0-7: 0
                        CAN status - brake control module 1-Bits 0-7: 0
                        CAN status - brake control module 2-Bits 0-7: 0
                        selected gear-Bits 0-7: 0
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans (J217)       Labels:| 0B5-927-156.clb
       Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
       Component: 0B5 30 TDIRdW H10 0006
       Revision: --H10---    Serial number: 0000000362
       Coding: 000001
       ASAM Dataset: EV_TCMDL501 A02206
       ROD: EV_TCMDL501.rod
       VCID: 2C57B2B1470B302A59-8078
    1 Fault Found:
    8007 - No Communications with Steering Angle Sender (G85)
              U0126 00 [039] - -
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 40
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine speed: 752 /min
                        Transmission input speed: 752 /min
                        Transmission output speed: 0 /min
                        Engine torque: -16 Nm
                        Transmission fluid temperature: 82 °C
                        Accelerator position: 0.0 %
                        Clutch status: Beide Kupplungen offen
                        Voltage terminal 30: 13.600 V
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.965 V
    Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V1.clb
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Revision: --------    Serial number: --------------
       Coding: 27A68701E465E180DB00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 004017
       ROD: EV_ESPPremiAU57X_004_AU57.rod
       VCID: 3467AAD19F3B68EA01-8060
    2 Faults Found:
    0067 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 41
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: D8
                        Uz: B0
    0848 - System Function Test Activated
              C101F 00 [009] -  -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 41
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: F8
                        Uz: B0
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
       Component: BCM2 2.0      H31 0330
       Revision: 00002001
       Coding: 05B82F06000000000000
       VCID: 78FF5EE1CBD34C8AED-802C
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H39 0046
       Serial number: 2311000115486015
    No fault code found.
    Address 06: Seat Mem. Pass
    Cannot be reached
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-4Z.clb
       Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
       Component: KLIMA 4 ZONEN H11 0056
       Serial number: 02061100040259
       Coding: 3621007820
       ASAM Dataset: EV_AirCondiComfoUDS 002029
       ROD: EV_AirCondiComfoUDS_002.rod
       VCID: 275D4D9D5EED1372B4-8072
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0100
       Revision: 20012002    Serial number: 00000001081552
       Coding: 2600201040349FE00181008380001D0C0F9DC30827090101000008602100
       Shop #: WSC 80093 222 71269
       VCID: 6DD17FB5B491F9220E-8038
       Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS57X 110518  H35 0051
       Serial number:         110523141032
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 11471490
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 26 05 2011  00000688
       Subsystem 4 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Component: AQ_Hum_Sensor  H02 0002
       Serial number: B8188CA5000000000001
    1 Fault Found:
    00466 - Control Module for Steering Column Electronics (J527)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Time Indication: 0
                        Date: 2019.12.29
                        Time: 04:19:00
    Address 0E: Media Player 1
    Cannot be reached
    Address 10: Park/Steer Assist (J446)       Labels:| 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0043
       Revision: 11001001    Serial number: 55901113900660
       Coding: 280306
       Shop #: WSC 00414 210 105479
       ASAM Dataset: EV_EPHVA18AU57X0000 002005
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: 3B7581EDB265A792C0-806E
    Address 13: Auto Dist. Reg
    Cannot be reached
    Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
       Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG002MUCI
       Coding: 30323436313330303537554A305234473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_VW51.rod
       VCID: 366390D989477AFA3F-8062
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB404P0ILP068S%
       Crash sensor for side airbag: front passenger side:
       Serial number: 3585HRB404P0ILP098FX
       Crash sensor for side airbag: rear: driver side:
       Serial number: 3515JRB40530I70GC8CR
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 3525JRB404T0IAME0OQ8
       Crash sensor for front airbag: driver side:
       Serial number: 3554VRB405V0HGJ8J9A9
       Crash sensor for front airbag: front passenger side:
       Serial number: 3564VRB405R0HGJ84GMA
    1 Fault Found:
    1050112 - Databus
              U1121 00 [009] - Missing Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:11
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
       Component: Lenks.Modul   H05 0201
       Revision: 00000000    Serial number: 20110530000293
       Coding: 000034
       VCID: 306FA6C1632354CA65-8064
       Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
       Component: E221 - MFL  H07 0009
    1 Fault Found:
    00576 - Terminal 15
                008 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Time Indication: 0
                        Date: 2019.12.29
                        Time: 04:19:09
    Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
       Part No SW: 4G8 920 981 S    HW: 4G8 920 981 S
       Component: TDieGb        H71 0375
       Revision: 26181114    Serial number: 658060611593051
       Coding: 33A608000B012600010000
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K.rod
       VCID: 4385F90DCA95DF5288-8016
    Address 19: CAN Gateway (J533)       Labels: None
       Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0204
       Revision: --------    Serial number: 00000000165092
       Coding: 00CD077D00
       Shop #: WSC 80093 222 69422
       ASAM Dataset: EV_GatewUDS 001025
       ROD: EV_GatewUDS_AU57.rod
       VCID: 306FA6C16B2354CA65-8064
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650597672
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
       Component: J532_DCDCStab  H05 0006
       Serial number: 11156000089021200410
    30 Faults Found:
    5729 - No Communication with Towing System Control Module (J345)
              U1003 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Voltage terminal 30: 13.5 V
                        Voltage terminal 15: 13.6 V
                        Control Module temperature: 42 °C
                        System status: Terminal 15 on
                        IN ESP_standstill flag: standstill detected
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status via CAN: On
                        Terminal 15 status: On
                        Datenfeld: 0
    5267 - Control Module for Special Purpose Vehicles
              U100F 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5268 - Vehicle Positioning System Interface Control Module
              U106F 00 [009] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5506 - Control module for rear lid electronics
              U1047 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5061 - Comfort system central control module 2
              U107E 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5735 - Seat/Mirror Postion Control Passenger - Driver
              U0209 00 [009] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5046 - Control Module for Multi-Contour Seat; Driver Side
              U1083 00 [009] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5047 - Control Module for Multi-Contour Seat; Passenger Side
              U1085 00 [009] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5048 - Control Module for Multi-Contour Seat; Rear Driver Side
              U1087 00 [009] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5049 - Control Module for Multi-Contour Seat; Rear Passenger Side
              U1089 00 [009] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5052 - Control Module for Seat Adjustment Rear Drivers Side
              U10B3 00 [009] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5053 - Control Module for Seat Adjustment Rear Passenger Side
              U10B4 00 [009] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5079 - Control Module for Convertible Top Operation
              U1098 00 [009] - No Communcations
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5714 - Control Module for Arm Rest Adjustment
              U10B7 00 [009] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:11
                        Voltage terminal 30: 13.6 V
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5603 - No Communication with Control Module for SRC Reductant
              U010E 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:11
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    4230 - No Communications with Steering Angle Sender (G85)
              U0126 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    4229 - Steering Effort Control Module
              U0130 00 [009] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5701 - High Beam Assistant Control Module
              U1070 00 [009] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:11
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    4888 - Camera control module
              U107A 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    4879 - Lane change assistant control module
              U1045 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5705 - Control Module for Head-Up Display
              U10B6 00 [009] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:11
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5080 - Front Left belt tensioner control module
              U107C 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5510 - No Communication with Gear Selector Module
              U0103 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:11
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    6653 - Image processing control module
              U1079 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5624 - No Communications with Structural Accoustics Module
              U10ED 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:11
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5792 - Heat image camera control module
              U107B 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:11
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5014 - Ride Level Control Module
              U0132 00 [009] - No Communications
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    5001 - Control Module for All Wheel Drive Clutch
              U0114 00 [009] - No Communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    4365 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    6654 - Automatic distance regulation 2
              U1071 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:11
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    Address 1B: Active Steering
    Cannot be reached
    Address 1E: Media Player 2
    Cannot be reached
    Address 20: High Beam Assist.
    Cannot be reached
    Address 22: AWD
    Cannot be reached
    Address 26: Auto Roof
    Cannot be reached
    Address 28: HVAC, Rear (E265)       Labels:* 4G0-919-158.clb
       Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
       Component: KLIMA FOND    H07 0056
       Serial number: 31051100040756
       Coding: 02
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
       ROD: EV_ClimaContrUnitRearUDS_002.rod
       VCID: 2F6DA5BD761D4B327C-807A
    Address 2E: Media Player 3
    Cannot be reached
    Address 30: Special Function II
    Cannot be reached
    Address 34: Level Control
    Cannot be reached
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 4G8 959 760     HW: 4G8 959 760
       Component: MEM-FS        H03 0153
       Revision: AA000000    Serial number: 00000006153919
       Coding: 00781B0000006001000001010101102030303232203232
       VCID: 77FD5DDDC6CD43F2E4-8022
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0004
       Revision: --------    Serial number: EJ1BPA320084JU0
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6BD571AD8285F71210-803E
    Address 3C: Lane Change
    Cannot be reached
    Address 3D: Special Function
    Cannot be reached
    Address 3E: Media Player 4
    Cannot be reached
    Address 40: AC Compressor
    Cannot be reached
    Address 42: Door Elect, Driver (J386)       Labels: None
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011C16205E01620002080002
       Shop #: WSC 02312 785 00200
       VCID: 428BFC09DD8FD65A83-8016
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
       Component: RCEPS         H33 0010
       Revision: 00001000    Serial number: 0028087174
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 326BACC9652F66DA13-8066
    3 Faults Found:
    3158276 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Write only channel
    4208000 - Steering Angle Sensor
              B1168 F1 [137] - Synchronization Failed
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Write only channel
    5258753 - Steering End Stops Not Learned
              C10AC F0 [137] - Unknown Error Elaboration
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Date: 2019.12.29
                        Time: 04:19:10
                        Write only channel
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0151164447
       Coding: 011B0E2200B9048183200804000100000000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177
       Component: DWA-Sensor  H01 0010
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Time Indication: 0
                        Date: 2019.12.29
                        Time: 04:19:09
    Address 47: Sound System (J525)       Labels: None
       Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
       Component: BOSE-G3-C7    H07 0160
       Revision: CJ007000    Serial number: 00000000003104
       Coding: 030000
       Shop #: WSC 20775 002 1048576
       VCID: 1D316F7504B1C9A2DE-8048
    Address 48: Seat, Rear, DS
    Cannot be reached
    Address 52: Door Elect, Pass. (J387)       Labels: None
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: 4189F305D889CD429A-8014
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
       Component: EPB-4         H03 0012
       Revision: --------    Serial number: 00000000082953
       ASAM Dataset: EV_ParkiBrake 001022
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A5BB4A94DFF2E1AAB-807E
    Address 55: Headlight Range (J431)       Labels:| 8X0-907-357.clb
       Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
       Component: ....LWR12.... H02 0013
       Serial number: 110604-0004-011
       Coding: 1121A6101000A300
       ASAM Dataset: EV_HeadlRegulBasic 005001
       ROD: EV_HeadlRegulBasic.rod
    Address 56: Radio (R)       Labels: Redir Fail!
       Part No SW: 4G1 035 053 J    HW: 4G1 035 053
       Component: Radio U Basic H41 0133
       Revision: AB001007    Serial number: 049FS0BB002243
       Coding: 010003010000000001
       VCID: 2643409951E70A7A8F-8072
    Address 57: TV Tuner
    Cannot be reached
    Address 5B: Seat,Rear,PS
    Cannot be reached
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 4G0 035 670 Q    HW: 4G0 035 670
       Component: H-BNT-EU      H47 1034
       Revision: --------    Serial number: 428F/0B7516339
       Coding: 050101000003A1EF45008B3E00000003000001000000000000
       VCID: 3169A3C568295DC26A-8064
       Subsystem 1 - Part No: 8R0 060 884 N
       Component: EUR 2011  1205
       Subsystem 2 - Part No SW: 4G0 919 605     HW: 4G0 919 605 A
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDB1300U6FP
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 A
       Component: E380 BDT C7  H08 0204
       Serial number: 90349KEQ0009C
       Subsystem 4 - Part No: 8R0 060 961 B
       Component: CD-Database  3371
    3 Faults Found:
    03276 - Please Check Software Version Management
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Time Indication: 0
                        Date: 2019.12.29
                        Time: 04:19:14
                 Freeze Frame:
                        Text: KBD_FC7,KBD,M,0,0,6
    00862 - Antenna for GPS Navigation (R50/R52)
                011 - Open Circuit
                 Freeze Frame:
                        Fault Status: 01101011
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Time Indication: 0
                        Date: 2019.12.29
                        Time: 04:19:23
                 Freeze Frame:
                        Voltage: 14.00 V
    03623 - Invalid Secruity/Release Code
                000 -  -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Time Indication: 0
                        Date: 2019.12.29
                        Time: 04:19:13
                 Freeze Frame:
                        Hex Value: 0x0004
                        Hex Value: 0x000B
                        Count: 6
    Address 62: Door, Rear Left (J388)       Labels: None
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010814204001620002080002
       VCID: 4487FA11C79BD86AB1-8010
    Address 69: Trailer
    Cannot be reached
    Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
       Part No SW: 4G0 907 441 B    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0061
       Revision: --H04---    Serial number: 525 PA8J1XG65M
       Coding: 1080004
       VCID: 2643409991E70A7A8F-8072
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 253
                        Mileage: 114926 km
                        Time Indication: 0
                        Date: 2019.12.29
                        Time: 04:19:09
                 Freeze Frame:
                            Term 15 On
                            Reverse OFF
                        Count: 3
    Address 6D: Trunk Elect.
    Cannot be reached
    Address 6F: Centr. Conv. II
    Cannot be reached
    Address 72: Door, Rear Right (J389)       Labels: None
       Component: TSG HR        H04 0212
    Address 7F: Inform. Electr. II
    Cannot be reached
    Address 81: Gear Shift
    Cannot be reached
    Address 82: Heads Up Display
    Cannot be reached
    Address 84: Night Vision
    Cannot be reached
    Address 85: On Board Cam.
    Cannot be reached
    Address 88: Multicont. Seat Driver
    Cannot be reached
    Address 89: Multicont. Seat Pass.
    Cannot be reached
    Address 8A: Multicont. Seat Rear,DS
    Cannot be reached
    Address 8B: Adaptive Cruise 2
    Cannot be reached
    Address 8C: Hybrid Battery
    Cannot be reached
    Address 8D: Multicont. Seat Rear,PS
    Cannot be reached
    Address 8E: Image Processing
    Cannot be reached
    Address 8F: Pretens. Frt Left
    Cannot be reached
    Address A4: Armrest
    Cannot be reached
    Address A9: Struct. Borne Sound
    Cannot be reached
    Address AC: Reductant Control
    Cannot be reached
    Address BA: Motor Mounts
    Cannot be reached
    End-------------------------(Elapsed Time: 09:32)--------------------------
    Meat-Head's Avatar
    Lost interest already
    eithrr some form of fuse your missing or its heen jumped off backwards
    is speedo display correct miles
    Jul 2019
    Quote Originally Posted by Meat-Head View Post
    all sorted, thanks.
    just blowed fuses.
    Meat-Head's Avatar
    Quote Originally Posted by Driuliauskas View Post
    all sorted, thanks.
    just blowed fuses.
    WELL PRESS THE THANKS BUTTON AND EXPLAIN WHERE SAID FUSE WAS!
  5. The Following User Says Thank You to Meat-Head For This Useful Post:
    rideon (2nd January, 2020)
  6. #5
    rideon's Avatar
    RO
    You should know better!
    The blown fuse was in the fusebox and the wire used to fix that was on the workshop floor
    A failure will not appear till a unit has passed final inspection
  7. The Following User Says Thank You to rideon For This Useful Post:
    Meat-Head (2nd January, 2020)
  8. #6
    Meat-Head's Avatar
    For your valid post ride on i have left money behind the counter at macdondalds fo you.
    but which 1 of 30,000 in world is your problem
  9. The Following User Says Thank You to Meat-Head For This Useful Post:
  10. #7
    rideon's Avatar
    RO
    Just came to say that
    1 security team@macdondalds is NOT happy if they find you behind the counter.
    2 only 29.998 left to check
    3 how much money ?
    4 I have better chance finding imaginary money than you getting an answer from OP
    5 imaginary friend missing for 2 days now
    4 how much money ?
    6 imagimary cat still here
  11. The Following User Says Thank You to rideon For This Useful Post:
  12. #8
    rideon's Avatar
    RO
    Meanwhile
    Run out of gas money,no more macdondalds in the area .Need help from DK members to find imaginary money
    Only 29.987 left to check!
    how much money ?
    I still believe I have better chance finding imaginary money than you getting an answer from OP
    Imagimary friend back
    how much money ?
    Imagimary cat still here
    Imagimary friend keeps asking what fuse & how much money?
  13. The Following User Says Thank You to rideon For This Useful Post:
    Meat-Head (17th January, 2020)
  14. #9
    Dunker's Avatar
    Yorkshire
    No lectrix to summat on J527 for a start ...
    Thought it was just me but everyone is just smacked out of their tits. I blame Meaty.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  15. The Following 2 Users Say Thank You to Dunker For This Useful Post:
    Meat-Head (20th January, 2020), rideon (22nd January, 2020)
  16. #10
    Meat-Head's Avatar
    Quote Originally Posted by Dunker View Post
    Elvis moment:-
    Confusion has over come my mind
    DISCLAIMER:-
    I didn’t purposely ask for my Siemens 2AS electic meter to be swapped for one that farts every hour
    at 50 mins past the hour
  17. The Following User Says Thank You to Meat-Head For This Useful Post:
  18. #11
    Jul 2013
    yorkshire
    smart meter eh, I keep telling lecky company no no no. There are too many spies out there already. My friend had one fitted and lost his inter web for two weeks.
  19. #12
    Meat-Head's Avatar
    No, NOT a smart meter, even ceo of energy companies knows i dont want smart one
  20. #13
    rideon's Avatar
    RO
    @ Meat-Head
    Kinda short of cash here.
    Me no luck yet finding money behind the counter at macdondalds
    Seems OP buggered off , that means no fuse location for you either.
    @Dunker I blame Meaty too
  21. The Following User Says Thank You to rideon For This Useful Post:
    Meat-Head (14th February, 2020)
  22. #14
    Meat-Head's Avatar
    Quote Originally Posted by rideon View Post
    Pick a window, your leaving.
    cant see anything in the rules about that.
    yes, im drunk, lost count after 4 pints
