galleto cant do this
use smok for this or kess
Hello guys,
I would like to ask which tool and protokoll need to choose for this car and ecu. 1.9 Tdi 90 HP ALH 1999 EDC15VM+ 29F400 no 2xplcc32!
I read with Kess v2 as ALH EDC15V with protokoll number 8, but strange thing is the diesel pump works during the whole readout. For AGV engine code Ksuite shows the
11 protokoll number for EDC15VM+.
So which protokoll I need to choose for writing a mod file?
I have also a Galletto V54 also but there is no other protkoll just EDC15V and that's all.
Galletto D1260 has also the same in the list EDC15V or Vm+ not have any different.
What advise you guys? Is the OBD write with Galletto will be safe (with battery charger) up to 12,5-13 V
Car: Seat Toledo 1999 1.9 Tdi 90 Hp ALH engine
Details
HW: 0281001061
SW:
VIN nr.:
SW ver.: 28SA4048
Spare:
Engine: 1,9l R4 EDC SG
HW Ver.:
SW upg.: 038906012AA 2514
Installation:
ECU Part Numbers:
BOSCH 0281010061 - 0 281 010 061
038906021AA - 038 906 021 AA
EDC15VM+
Thanks for the help
PRESS THANKS AND REPUTATIONS (STAR) BUTTON
I don't give others the password to the file. I'll send my file and I'll try to make it
Mpps v16 and v18 can do this ecu no problem
TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
SPECIALISE IN TUNING DIESEL ENGINES
(DEMON DEVELOPMENT)
IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
Just have Kess V2, Galletto V54 and Galletto D1260
Hope if read than do the write with no problem
Use kess make sure to have battery charging during write as the fuel pump works during write too usually if read without problem then should write without problem
(DEMON DEVELOPMENT)
Also V54 can r/w this ecu no problem just use edc15v from list
(DEMON DEVELOPMENT)
user202 (2nd January, 2020)
unsolder am29f
save org.file and write your mod
i read and write that ecu with fgtech also without pulling fuses
(DEMON DEVELOPMENT)
Used mpps v16 chinese, read/write many times no problem. Problem can be with mpps v13.02 it can trigger security code error.
1260 fgtech perfect tool for this ecu
