Results 1 to 12 of 12
    Wirral
    Default Renault ECU decoder Connections
    Hi all,
    Im have got a Safir 2 ECU i need to decode, with the ecu decoder, But im not to sure about the connections. You need a relay for this type of ECU which iv not used before. How do you connect up the relay, and anyone got a link for one that would be sutable? Also, connecting power etc to the box, do you just splice it into the 12v and ground cables running from the decoder?
    Any help / pics would be great! i have the manual, just not sure how to connect.
    Thank You
    Jamie.
    Eastern Europe
    hi,
    Any 12V DC relay with reasonable power consumption. You need also a lamp - max 3W, that's the limit.
    regards
    Lithuania
    Hi, can help to connect......
    Wirral
    Spot on arvydax, Just what i needed. Thanks!!
    bonsoir j'ai le meme probleme est ce que je pourrai savoir comment je dois faire connecter entre le decodeur et ecu merci de me repondre
    Hey I have the same problem is that I can know how I have to connect the decoder and ecu thank you for reply
    thank you very much for the manual very nice
    Aug 2010
    thanks about this info
    darwins's Avatar
    UK
    Dear Group
    I have one of these : http://www.tek-tronics.co.uk/product_info.php?cPath=34&products_id=59
    Done a fair few units, but never a Safir2, I have a couple of questions can you help...
    Does the bulb flash continuosly during decode ?
    When its decoded does the light still flash when powered up on bench ?
    Darwins..
    ALGERIA
    Quote Originally Posted by arvydax View Post
    mmmmm very interesting PDF have you got other like this for peugeot?
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by darwins View Post
    Dear Group
    Darwins..
    For safir 2 ecu:
    bulb flashes as decoding m8. before start decode must be in advanced 1, press mode button once.then start button
    Will go on for about 4 hours m8
    After decode bulb stays lit continously bar on early safir2 where bulb comes on then goes off after few seconds
    You need every tool in the book, to do this auto locksmith job.
    darwins's Avatar
    UK
    Thank you obdmaster for this information..
    My decoder is faulty, it's not driving the relay through yellow cable, checked joints etc.....
    I carried out the process in this post: http://www.digital-kaos.co.uk/forums...2-43kw-151224/ It has deffo cleared the IMMO just need to hook up to a car later and see if the unit still works
    If i don't call back on this by the end of today its worked...
    Darwins
