Results 1 to 8 of 8
    Dec 2019
    Default Immobilizer 00003 - Control Module 014 - defective
    Hi after changing the mileage of instrument cluster 1ZO 920 842 D
    With abrites tool
    SKODA OCTAVIA II (2006)
    I feel the error started coming.
    I even changed the mileage in ecu also to help this error go, but stays permanent.
    IMMOBILIZER
    00003 - control module 014 - defective
    Freeze frame :
    Fault status : 01101110
    Fault priority : 2
    Fault frequency: 1
    Any help ?
    How to correct this
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    post original file and edited file
    Dec 2019
    I just have edited file. Can i post only that only ?
    Sep 2013
    That's not enough. To compare files and see your edition I need the original file and edited file. (You always have to save original files....always )
  5. The Following 2 Users Say Thank You to jomberykaso For This Useful Post:
    rafal (7th January, 2020), stoyanov (7th January, 2020)
    Dec 2019
    i have downloaded eeprom, flash of same model 1z0920842D of some other vehicle,
    and my eeprom, flash after mileage change.
    can it help
    Sep 2013
    No mate. If you do that....you only will be posting 2 different fIles from 2 different cars. How could we help you with files of 2 different cars?....however always there is a solution
    Dec 2019
    Quote Originally Posted by jomberykaso View Post
    what should i do next
    can i leave it as it is, because there is no warning light, and car works as normal.
    update: Error goes temporary if i click on (Diagnostic session 86 ENTER) in abrites Immobilizer menu
    But it comes back again after some time
    May 2015
    GB
    Hello can someone help me I have a Passat b6 I have a problem with the immobilizer my spiral glides on the board and does not start the car and gives me this error
    IMMOBILIZER
    Freeze frame :
    Fault priority : 2
    Fault frequency: 1
    after i delete with the vcds the error machine starts up goes normal thanks.
