HELLO
can someone check or improve my file PLEASE
I only have 1.6 bar, so I set it to 2.5 bar
turbo 2260vk mfs
desi injector + 90%
CLUTCH SPEC STAGE 3
THANKS
HELLO
turbo 2260vk mfs
desi injector + 90%
CLUTCH SPEC STAGE 3
THANKS
Hi mate,
Your SVBL is stock at 2620mBar.Your Boost sensor is limited to 3000mBar.
No ori file , no car data, nothing.We must guess is an Ibiza Cupra.The one we suppose would help you must look an net for original file, extra work and wasted time.
Your file is a shit.it is not worth trying to correct it.
Real engines don't need forced induction
Who needs a turbo when you have a stupidly quick naturally aspirated engine?
its not very good mate you put this on your car wont last that long and looking at your torque limiter its lets say..... like mount Everestclutch wont last long at all even with your stage 3 clutch and as NEST said unless you have a 4 bar map sensor your map sensor is limited at 3000mbar yet your asking for 3400mbar
if i was you i would start over or take it to a tuner
TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
SPECIALISE IN TUNING DIESEL ENGINES
(DEMON DEVELOPMENT)
IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
hello
thank you for taking the time to answer me
I have a 4 bar sensor but I may have been badly calibrated
I post my original file to you
the car is a seat cupra
If u put 4bar map after remap u need to do remap again and enter that 4bar map in you file...
That engine can output big power if u got all right parts and at last one good, good map...
Bigger intercooler, bigger turbo, bigger injectors, bigger maf, bigger map, exhaust and at last good mapping...
Good luck!
Poslato sa VTR-L09 pomoću Tapatoka
hi
all the pieces that you quote I already have on the car
just missing a good mapping
i will try modify again to see
If that was my car i will never "try mapping" that spec. car, better find some proper tuner and pay them right - got your car safe...
chrisimerk (8th January, 2020)
