No you need Original Tool for VR Reading....
Dont understand why everybody buy this shit clone tools....if need original slave tool write pm.. is cheaper you think and they work
Hello everyone, starting out in reading ecu I bought a KESS V2 equipped with a second black case. I would like to read the ECU from my 2009 scirocco.[
Since it is MED17.5 I have to switch to tricore or bootmode, but I do not understand if I can achieve it with KESS V2 ?
Thank you for your answers friends !
you can read/write tricore/boot with kess v2
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
allchopper (8th January, 2020)
Ahh perfect friend, it seems to me that i don't need external additional 12v power supply?
Have to use the small black box and connect/solder the gray wire to boot and the other to the ECU pin right ?
Thanks for your replies friends
Goit seems to me that i don't need additional 12v power supply?it seems to me that i don't need additional 12v power supply?
thats right and a bit of pray to god
Lol why i need to pray ?
because user of clone tool?
As clone tool your you should everytime pray for working .
Ohh ok i understand, i don't need external power supply ? just connect to the boot and ecu pin and start K-suite ? Will do it tonight i think toom uch happy to do that kind of thing !
you need external power supply, a good one.
Arf ok thanks need to order one so. Can you take a look at my picture in mine 2nd post. This builds and cable is OK ?
look here
allchopper (9th January, 2020)
Yes i've save this pictures already to connect to the ECU but kess V2 + the little black box (What name is it ?) is ok to do a bootmode ? Everybody are talking about KTAG bootmode, nothing about this black module ...
Thanks for your replies mate
kess V2 + the little black box and +12v and you can work with kess
Ok thanks, did you have a link for a good external power supply ? I see so many price from 2Eur to 200Eur
Best is buy geniune tool, you heared 100 times i know. If you dont have experience to open ecu, don't do the job.. It's riskly
If you have protocol 463 (only id and write) do id and upload ID here, i will give ori VR file that you can write..
New year gift 1 time.
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
serdarurer (21st January, 2020)
