Results 1 to 10 of 10
    Dec 2010
    Default Opel CDR 2005 VDO code
    Please need code from this dump Opel CDR 2005 VDO. Thanks
    rdu04's Avatar
    Nov 2009
    RO
    code is 7870,if is good,use thanks button or write this eprom,no code
  3. The Following User Says Thank You to rdu04 For This Useful Post:
    jacostanzo (8th January, 2020)
    Jan 2020
    Moldova
    enter the code twice and it will be without a code
    Jan 2020
    Finland
    CDR2005 330886836
    GM020531797648
    can you find code for this radio?
  6. #5
    Oct 2013
    Ukraine
    Quote Originally Posted by peete View Post
    CDR2005 330886836
    GM020531797648
    Hi, read eeprom 24c16 and post here
  7. #6
    Jan 2020
    Finland
    Jan 2020
    Finland
    how do i read eeprom?
  9. #8
    Oct 2013
    Ukraine
    Hi, you need to collect a programmer for example ( PonyProg ) http://www.lancos.com/prog.html
  10. #9
    Jan 2020
    Finland
    Quote Originally Posted by masterskay62 View Post
    so its not possible to get the pin code to open using the serial number?
  11. #10
    Jan 2020
    Czech rep.
    Post
    Yes, pin from S/N is not possible. Only from eeprom dump. Or try ask dealer.
